l67ss Posted May 13, 2014 Report Posted May 13, 2014 lol I dunno man I might when I destroy this transmission Or mebbe after I swap to one up me Quote
nitehawkjcb Posted May 13, 2014 Report Posted May 13, 2014 Nah man never to one up... just to keep up Quote
l67ss Posted May 13, 2014 Report Posted May 13, 2014 Nah man never to one up... just to keep up ^this coming from the guy with the faster monte Quote
nitehawkjcb Posted May 13, 2014 Report Posted May 13, 2014 Hey I don't know it's faster, you could have a cam and some spray that I don't know about..... Quote
l67ss Posted May 14, 2014 Report Posted May 14, 2014 Not yet Hey I don't know it's faster, you could have a cam and some spray that I don't know about..... Quote
carkhz316 Posted July 28, 2014 Author Report Posted July 28, 2014 Just a little update. I finally got around to playing with HP Tuners a few days ago and turned off/ disabled all the trans codes and now the cruise control works. My wiring procedure for the clutch switch works as planned too. With a touch of the brake pedal or the clutch pedal the cruise disables as expected. Quote
nitehawkjcb Posted July 28, 2014 Report Posted July 28, 2014 Great to hear! Killer setup man. And cruise control? WINNER! Quote
19Cutlass94 Posted July 30, 2014 Report Posted July 30, 2014 That's one thing l wish my car had, was cruise control. Go4DaMo 1 Quote
pshojo Posted July 30, 2014 Report Posted July 30, 2014 so whats the desl with cruise control? do most of these swaps not have cruise? whats the difficulty? Quote
carkhz316 Posted July 30, 2014 Author Report Posted July 30, 2014 I'm guessing some folks just have general problems with the cruise being inoperable. In the case of the manual trans swaps, it's a matter of either the range position switch being in the right position to enable cruise (drive range) and/ or the trans codes inhibiting cruise. My dumb ol' Haynes manual doesn't give pin numbers/ letters for most of the wiring diagrams (cruise control module included) so I had to do some digging to guess which one of the 2 dark green wires was the VSS and which one was the cruise inhibit. I thought if I bypassed the the inhibit signal that it would force the cruise to engage. It turns out I had pulled the VSS wire instead, because when I plugged it back in (after already turning off the trans codes in the PCM) it started working. Regarding the wiring I did in my swap: that was just for the disable to work with the clutch pedal as well as the brake. While not absolutely necessary, I wanted the redundant, factory like function of it; and for safety and stuff. Go4DaMo 1 Quote
l67ss Posted August 8, 2014 Report Posted August 8, 2014 if you go to print this thread its 102 pages long lol Go4DaMo 1 Quote
Nas Escobar Posted August 9, 2014 Report Posted August 9, 2014 if you go to print this thread its 102 pages long lol You actually printed this thread? Go4DaMo 1 Quote
l67ss Posted August 9, 2014 Report Posted August 9, 2014 Yup i like hard copies of info i need in case the electronic source fails or i go very long w/o net service. Printed bumpin96montes l67 swap how to off mymonte.com, 6 monthes later the forum died You actually printed this thread? Go4DaMo 1 Quote
Nas Escobar Posted August 9, 2014 Report Posted August 9, 2014 That is valid. I usually save stuff on my flash and SD card Sent from my HTC Sensation using Tapatalk Go4DaMo 1 Quote
Cully77 Posted August 9, 2014 Report Posted August 9, 2014 Yup i like hard copies of info i need in case the electronic source fails or i go very long w/o net service. Printed bumpin96montes l67 swap how to off mymonte.com, 6 monthes later the forum died Ugh. We died a slow painful death. I wish chad would have switched over to here. I think he pops up on MCF every once in awhile, but I would love to know how he's doing with the whipple set up these days. Quote
carkhz316 Posted August 10, 2014 Author Report Posted August 10, 2014 102 pages? Holy cripe. Must be all the pics and graphics or something. Quote
Go4DaMo Posted November 30, 2024 Report Posted November 30, 2024 (edited) On 7/29/2013 at 9:07 PM, carkhz316 said: If you are using the stock clutch hydraulics with the accumulator, everything should just bolt right up. The accumulator bolts right next to the slave cylinder on the trans. If, on the other hand, you want upgrade the hydraulics to eliminate the accumulator, see this thread: http://www.w-body.com/showthread.php/76462-Getrag-284-282-SS-braided-clutch-hydrualics-bleeding-procedure I went head and purchased the following from the thread: http://i1177.photobucket.com/albums/x349/Carkhz316/IMG_20130529_005140.jpg Bought this today, as my accumulator has air in it. Thank you!! Edited December 1, 2024 by Go4DaMo To be moar Pacific. SuperBuick and carkhz316 2 Quote
Go4DaMo Posted December 1, 2024 Report Posted December 1, 2024 On 8/9/2014 at 6:24 AM, l67ss said: Yup i like hard copies of info i need in case the electronic source fails or i go very long w/o net service. Printed bumpin96montes l67 swap how to off mymonte.com, 6 monthes later the forum died Smart Quote
Go4DaMo Posted December 1, 2024 Report Posted December 1, 2024 (edited) On 7/29/2013 at 9:07 PM, carkhz316 said: (...) http://i1177.photobucket.com/albums/x349/Carkhz316/IMG_20130529_005140.jpg If you follow the above thread, you'll be able to get rid of that crappy accumulator and have a nice firm clutch. UPDATE: This link proved useful: Did this link get moved somewhere? http://www.w-body.com/showthread.php/76462-Getrag-284-282-SS-braided-clutch-hydrualics-bleeding-procedure Edited December 1, 2024 by Go4DaMo For the love of w-body! SuperBuick 1 Quote
carkhz316 Posted December 22, 2024 Author Report Posted December 22, 2024 On 11/30/2024 at 7:59 PM, Go4DaMo said: UPDATE: This link proved useful: Did this link get moved somewhere? http://www.w-body.com/showthread.php/76462-Getrag-284-282-SS-braided-clutch-hydrualics-bleeding-procedure Yeah, I'm not sure what happened with the broken link. The Deboss garage link is basically the same strategy though. One removes the slave and manually actuates it in reverse to bleed the system. Thats all one needs to do. Its just awkward in the car with limited space to work. SuperBuick 1 Quote
