kbrown112993 Posted July 9, 2013 Report Posted July 9, 2013 Hey guys this is my first time using this forum I need your help, I have a 1995 Olds Cutlass Supreme, my engine blew, and I have found a 2000 3100 V6 with only 88,000 miles on it for 500 dollars, would it be able to work on my 95 Cutty??? Quote
LumiLTZ Posted July 9, 2013 Report Posted July 9, 2013 I think it would.... Thought you'd probably have to swap the top end (intake, etc) and accessories over. I'm not the most familiar with changes with the 3100 over the years. Quote
RobertISaar Posted July 9, 2013 Report Posted July 9, 2013 could use it as-is and work around a few issues(EGR, coolant temp sensor), or use from the LIM upwards from the 95 on top of the 00 block/heads. Quote
pshojo Posted July 9, 2013 Report Posted July 9, 2013 I'd be tempted to find a 3400 and use that as replacement. Quote
l67ss Posted July 18, 2013 Report Posted July 18, 2013 Hey guys this is my first time using this forum I need your help, I have a 1995 Olds Cutlass Supreme, my engine blew, and I have found a 2000 3100 V6 with only 88,000 miles on it for 500 dollars, would it be able to work on my 95 Cutty???I hav a 2002 3.4 n my 97 monte use ur original tb Quote
l67ss Posted July 18, 2013 Report Posted July 18, 2013 Hey guys this is my first time using this forum I need your help, I have a 1995 Olds Cutlass Supreme, my engine blew, and I have found a 2000 3100 V6 with only 88,000 miles on it for 500 dollars, would it be able to work on my 95 Cutty??? Sum 2000 3.1s had piston issues so try to hear it run first Quote
