GPdriver1986 Posted November 9, 2003 Report Posted November 9, 2003 I was looking at some oil leak stop products at Crappy Tire, they have a few, it says that it won't clog any small passageways. Anybody try using these products? Quote
sonyman87 Posted November 9, 2003 Report Posted November 9, 2003 I was looking at some oil leak stop products at Crappy Tire, they have a few, it says that it won't clog any small passageways. Anybody try using these products? Bad Idea! it makes your oil thicker is what it does. its like dumping 20w-40w into your motor... if you have an oil leak lookup the oilpump O-ring. Its the number 1 oilleak on a w-body specificly. Keep using the specified oil and fix the leak. or if its a slow leak watch it carefully and as soon as it gets bad take care of it then. Quote
gp90se Posted November 9, 2003 Report Posted November 9, 2003 I was looking at some oil leak stop products at Crappy Tire, they have a few, it says that it won't clog any small passageways. Anybody try using these products? Bad Idea! it makes your oil thicker is what it does. its like dumping 20w-40w into your motor... if you have an oil leak lookup the oilpump O-ring. Its the number 1 oilleak on a w-body specificly. Keep using the specified oil and fix the leak. or if its a slow leak watch it carefully and as soon as it gets bad take care of it then. yup, dont screw around in winer with the additives, fix the problem. -Jeff Quote
J Posted November 9, 2003 Report Posted November 9, 2003 you guys ever see motor honey!? HOLY SHIT IT"S THICKER THAN HONEY Quote
