Oil Leak on passenger side, serpentine belt, alternator, where is it coming from?
Hi, I'm new. Thanks in advance.
I have a 1997 cutlass supreme, 3.1 V6. The car started leaking oil several months ago on the passenger side of the engine. It leaks more when it's hot. I can't tell where the oil is coming from, and it's getting onto the serpentine belt and splattering around, which makes it tough to localize the source. I had it at a shop; they power washed the oil off, and let the engine run, but they told me they couldn't find a leak. And it actually didn't leak after that for quite awhile. I'm guessing because it was not hot enough. Now that we're in the midst of summer, I'm leaking a fair amount of oil, and I'd like to get it taken care of. What are common things that would leak oil on that side of the engine?
My 95' GP with the 3.1 V6 had a small oil leak when I bought it. After I power washed the engine, was able to pinpoint my leak in the oil pan gasket directly behind the harmonic balancer. The oil would pool around the motor mount. I torqued up the pan bolts and added some oil stop leak and It went away.
Yeah, I have a mysterious leak in that spot too on my Lumina. I figured it was the LIMG, but that didn't fix it when I replaced it... I can't see where it's coming from either, but it's annoying me, lol.
Could be valve cover gaskets, LIM gasket, timing cover gasket, Timing cover seal, oil pan gasket, head gaskets. All of those youll need to check.
