GrandPrix34 Posted November 8, 2003 Report Posted November 8, 2003 On the tensioner, do i pull up or push down to adjust the serpentine belt? The damn belt keeps slipping to the very end of the pulley. Is this a bad pulley? or was the belt just not seated right? By the way, wat tool can I use to really make life eaiser on me? Quote
desertdog71 Posted November 8, 2003 Report Posted November 8, 2003 Sounds to me like the belt wasn't seated correctly, also do you have an idler pulley? If so check that the pulley is turning freely, if it starts to seize up, that can throw the belt off also. But if not, and you get it seated properly, it should stay on no problem. Quote
PaPaPooh Posted November 8, 2003 Report Posted November 8, 2003 my 2.8 is up to loosen. i read that they are self adjusting as the belt wears but im not sure on the 3.4 Quote
Dannymik Posted November 8, 2003 Report Posted November 8, 2003 pull up to release. I bought some long tool that is for this at AutoZone. It looks like an extended rachet(<---spelling?). Quote
GrandPrix34 Posted November 8, 2003 Author Report Posted November 8, 2003 wat tool can be used though? I forgot wat tool i used to install the FFP pulley and readjust the serpentine belt. THe ratchet does not fit in that confined area... *edit* WHY in God's name is the bolt unscrewing?? I pulled up and the bolt on the tensioner loosened :shock: Quote
Redfox340 Posted November 8, 2003 Report Posted November 8, 2003 On the tensioner, do i pull up or push down to adjust the serpentine belt? First, there is no adjustment... that's what the tensioner is for. But to loosen the belt, you push down on the tensioner. wat tool can be used though? I forgot wat tool i used to install the FFP pulley and readjust the serpentine belt. Use a 14mm or 15mm (whatever size, can't remember hand) open side wrench. Not that much torque is needed to give the serpentine belt much slack. - Erik Quote
GrandPrix34 Posted November 8, 2003 Author Report Posted November 8, 2003 when i meant adjust i meant readjust cuz the belt is slipping off the tensioner...its about 1/2 way off! :shock: Bad tensioner? Quote
Redfox340 Posted November 8, 2003 Report Posted November 8, 2003 when i meant adjust i meant readjust cuz the belt is slipping off the tensioner...its about 1/2 way off! :shock: Bad tensioner? Half-way? :shock: Yeesh! Is the tensioner firmly bolted to the block? If it is, and still a problem, I would say a new one is in order. - Erik Quote
Aaron Posted November 9, 2003 Report Posted November 9, 2003 i use a 19mm(?) wrench, it is DOWN to lossen tensioner, by going up you just loosen the bolt. Quote
Slade901 Posted November 9, 2003 Report Posted November 9, 2003 To adjust the serpentine belt, you must turn the tensioner counter-clockwise. BTW, check to make sure that the tensioner bold is not loose. Quote
Aaron Posted November 9, 2003 Report Posted November 9, 2003 it is clockwise and i am absolutely positive. Quote
