repairing ruptured coolant pipe
It starts out in life as rubber, then becomes metal. Runs underneath the overflow bottle (1992 3.1 Lumina). I was just going to cut the pipe, then put a piece of 3/4" heater hose and 2 clamps. Whaddaya think?
It broke on a really cold night last winter. Smushed epoxy putty worked pretty well until it got hot.
If you use a rubber hose, you may have problems with rubbing.
I'd prefer to use 3/4" Copper Type-L Pipe (~$25 at Home Depot).
http://www.homedepot.com/p/Mueller-Streamline-3-4-in-x-60-in-Copper-Type-L-Pipe-LH06005/100345178
Make sure you get the L type, and not the thinner M type. :)
You could put one end in a vise, and use a towel, along with heavy gloves, to bend the free end. Avoid using grip pliers, etc, since they can crush and damage the pipe. You'd likely need to heat the pipe with Propane/MAPP gas to bend it properly. Note, you must wear heavy leather gloves. It's easy for your hand to slip and get a very nasty burn.
I would use a pipe bender or a conduit bender. :) It's safer (less likely to damage/bend the pipe) and easier. :)
Of course, a 3/4" pipe bender is the best way to bend the pipe. And, no heating would be required.
Or, use a 3/4" conduit bender. That would also work fine. And, again, no heat required.
They are a few 3/4" conduit benders on ebay for ~$25. Search for:
3/4" conduit bender
You'd need to add a 3/4" handle.
If you search on ebay for
3/4" pipe bender
you'll find some used ones for ~~$35 (incl S&H) with handle.
Or, new from Home Depot for ~$45 with handle.
http://www.homedepot.com/p/Klein-Tools-3-4-in-Conduit-Bender-and-Handle-56207/100660160
Hey, even with getting everything from Home Depot, it would still be cheaper than 1 hour of mechanics time. :) And, that new pipe section will outlast the car. Better to do it once, and do it right.
Good Luck!
Edited by Cutlass350
I just removed the entire assembly and ran soft heater hose from where it exits the water pump and plugged it into the heater core.
i thought the replacement pipe was discontinued? at any rate, mine is also a rubber hose all the way now
  • 2 weeks later...
That was my doing on that car. lol
On mine, it ruptured a couple of inches above the crimp...so I got a metal sleeve, and hose clamped that in place.
i had replaced it with a nos part on my cutlass. When I got your tgp I decided the full rubber line was superior, the factory part was already starting to rust
Sounds like a good piece of information for the Part Number sticky...
The original part is GM # 10145142. There's an aftermarket Dorman replacement, #626-100. They run about $30 shipped on eBay.
http://www.ebay.com/itm/DORMAN-626-100-Heater-Hose-/390597626865?pt=Motors_Car_Truck_Parts_Accessories&hash=item5af16ecbf1&vxp=mtr
A rubber hose might last longer, but the OEM style part should also last at least a decade.
That part lists for 91/92 only but works just as well in a 90'
