l67ss Posted July 23, 2013 Report Posted July 23, 2013 First thing check the wheel bearing mine caused my bake to squeal check the caliper bracket clips for wear and alignment and damage also ceramics r crap Quote
ILoveSun Posted July 26, 2013 Report Posted July 26, 2013 First thing check the wheel bearing mine caused my bake to squeal check the caliper bracket clips for wear and alignment and damage also ceramics r crap What are the caliper bracket clips? I put on new pads today - no change. Went and bought new caliper - no change!!! This is freakin' driving me insane! It's louder now than when I started swapping parts(?). Greg Quote
ILoveSun Posted July 26, 2013 Report Posted July 26, 2013 Also, did you have o replace your wheel bearing or just repack it? Or is it one of those "sealed hub" designs where the entire hub unit has to be replaced rather than just getting the bearing? Greg Quote
l67ss Posted July 26, 2013 Report Posted July 26, 2013 Theyre wut the pad sits on u c them wit da pads off Quote
ILoveSun Posted July 26, 2013 Report Posted July 26, 2013 Only thing there with the pads off (both old and new calipers) is the pistons on the inside pad and the caliper itself on the outside pad. The inside pad has prongs that clip into the ID of the pistons and the outer pad has a permanently attached clip that slides over the middle of the outside edge of the caliper, locking it in place. Quote
urbex Posted July 26, 2013 Author Report Posted July 26, 2013 Only thing there with the pads off (both old and new calipers) is the pistons on the inside pad and the caliper itself on the outside pad. The inside pad has prongs that clip into the ID of the pistons and the outer pad has a permanently attached clip that slides over the middle of the outside edge of the caliper, locking it in place. Yeah, that's all mine have too. I know some cars have extra clips, but I never got any for any set I've had on the Lumina. Quote
ILoveSun Posted July 26, 2013 Report Posted July 26, 2013 Well I purchased a right front hub/bearing assy today and will try and get it on soon and give an update. Lord, PLEASE let this fix the issue! Greg Quote
ILoveSun Posted July 31, 2013 Report Posted July 31, 2013 Well, I replaced my front hub/bearing assy today and while I was torquing the front lugs the car rocked and I heard a chirp. It came from the REAR!!!! When I bought the car the owner said the chirp was from the front, and every time I would pass by something, that's where it sounded like it was coming from. Oh well. Picked up rear pads and a hub assy today and will work on the rear tomorrow. This thing is kicking my ass! Greg Quote
19Cutlass94 Posted July 31, 2013 Report Posted July 31, 2013 I dont mean to be an ass here, but instead of wasting your money, why dont you have a friend help you out in figuring out the issue... Quote
ILoveSun Posted July 31, 2013 Report Posted July 31, 2013 You're not being an ass at all. The rear will be easier to diagnose as I can jack it up and remove the caliper and rotate the wheel. That way I can isolate where the noise is coming from. Yes, I could have done that with the front, but to be honest, I never considered it because each time I was confident the part would fix it. Sometimes I'm a very slow learner! Quote
