Chris2012 Posted June 11, 2013 Report Posted June 11, 2013 Spray dry gas around the ignition wires with a spray bottle? I usually use a heat lamp or hair dryer, but I'll risk draining my battery in this instance. I've had to do this 10 - 20 since I trusted some idiot to replace my ignition module. Quote
rich_e777 Posted June 11, 2013 Report Posted June 11, 2013 You cannot spray dry gasoline with a bottle, you need to add water first:D Ha couldn`t help it, its been a long night. I`d use brake cleaner first then WD-40 if I didn't have any of the first. Year? Make? Model? Engine? Are you sure its moisture and not a loose or bad connection? Quote
RobertISaar Posted June 11, 2013 Report Posted June 11, 2013 "dry gas" is simply isopropyl alcohol. it would evaporate quickly enough. Quote
dodgethis Posted June 11, 2013 Report Posted June 11, 2013 "dry gas" is simply isopropyl alcohol. it would evaporate quickly enough. Did not know that. Quote
RobertISaar Posted June 11, 2013 Report Posted June 11, 2013 yeah. sometimes, you can find 99% iso alcohol in pharmacies for a lot cheaper than what ISO-heet and others cost. i don't think i would use any lower than the 91% stuff that gets sold though, otherwise you're just putting more water in your tank. Quote
Schurkey Posted June 11, 2013 Report Posted June 11, 2013 Spray dry gas around the ignition wires with a spray bottle? I usually use a heat lamp or hair dryer, but I'll risk draining my battery in this instance. I've had to do this 10 - 20 since I trusted some idiot to replace my ignition module. How do you know that moisture is the problem? Seems unlikely to be moisture-related if I understand you correctly, and you've had the engine running 10--20 times. The engine heat would tend to evaporate the moisture. Outright defective spark plug wires--or some other component--seems much more probable. Quote
