z34mightymachine Posted June 8, 2013 Report Posted June 8, 2013 On my gauge cluster my the indicator for my battery gauge always stays at 18. Is there anyway to fix it to work and read properly? It has not worked for a while. My Battery is fairly new. Quote
Schurkey Posted June 9, 2013 Report Posted June 9, 2013 On my gauge cluster my the indicator for my battery gauge always stays at 18. Is there anyway to fix it to work and read properly? It has not worked for a while. My Battery is fairly new. Of course there's a way to fix it. First, you find out what failed. Then you repair it. Could be defective wiring to the cluster, could be defective wiring inside the cluster, could be a defective gauge. Since the gauge reads high instead of low, it's likely the gauge. You are best off to buy a service manual for your vehicle, perform tests as required. This will almost certainly involve taking things apart for access to test points. Quote
