how to get a trans to hold on a little longer
Guest Eurolumina92
i have a 4 t 60 e that doesent want to shift in to the next gear up even manual over ride doesne work what can i do to get a week or so out off it
Don't mean to state the obvious, but have you checked the fluid? Drop the pan and change the fluid and filter if it's any color other than the 'normal' pinkish. It could help you get a bit more out of it.
Do what he says and also add a bottle of Lucas trans fix.
If the trans is cooked then throw some trans-medic in it see if that helps
No, don't half-ass a tranny issue... it only progresses to a worse condition.
Being a quick-lube tech, follow Rob95CS and 91cutty advise.
Do a complete drain, flush and fill of the transmission before anything else.
Old, burnt fluid is one of the most single related problems to a slipping and disengaging tranny.
- Erik
