mchill07 Posted June 3, 2013 Report Posted June 3, 2013 I Managed to get my turn signal switch replaced this afternoon... what a job! All went well. When checking out if everything was working properly.. I noticed that my low/high beams work with the head lamps on, but with the headlamps off the high beams don't flash. I don't remember seeing them in the flash in the past b4. Do the 1'st gen W-body's have this feature or is there a problem? Quote
WhatTheFehl Posted June 3, 2013 Report Posted June 3, 2013 My first gen did not have that feature. I don't believe it was availble. Quote
ManicMechanic Posted June 3, 2013 Report Posted June 3, 2013 My 1992 Cutlass had it, my 1994 did not. I believe 1988-93s had it. This is something I want to add to the Indy and Blazer at some point. Quote
RobertISaar Posted June 3, 2013 Report Posted June 3, 2013 i'm fairly certain 90GPROTBOX had it.... and it was a pretty optionless car. Quote
Galaxie500XL Posted June 3, 2013 Report Posted June 3, 2013 My '95 Cutlass doesn't have it, either... Quote
Galaxie500XL Posted June 3, 2013 Report Posted June 3, 2013 Same here. They think the Interstate is actually a NASCAR track, if they let you pass, they lose. the idiots here freak out if you do that Quote
Night Fury Posted June 3, 2013 Report Posted June 3, 2013 My 88 has flash to pass. Used it just the other day to signal a semi over in broad daylight in fact. Quote
