I have quarter window weatherstrip . I'm trying to pull off the moulding that covers it. How do you? I have front screw out and cut the double sided tape up to quarter window where it curves. What holds rest on?
You got the easy part done, now there's...I think 3 (maybe 4) speed nuts accessible through the trunk behind the carpet\trunk material. IIRC you also have to remove the rear strip with the cyclops light in it - the ends of that overlap the side pieces.
