mediabandit Posted June 1, 2013 Report Posted June 1, 2013 Hi guys, where is the ECM fuse located on a 1991 Lumina Z34 3.4 Dohc? Quote
RobertISaar Posted June 1, 2013 Report Posted June 1, 2013 driver's side strut tower, in a little plastic enclosure with the fuel pump relay. Quote
mediabandit Posted June 1, 2013 Author Report Posted June 1, 2013 Thanks Robert going to go check it now. Quote
RobertISaar Posted June 1, 2013 Report Posted June 1, 2013 oh, and there's also a second one.... the one i mentioned is the "voltage always present" one that retains the NVRAM in the ECM. the other is in the in-cabin fuse panel, that one is used as a signal for the ECM when the ignition switch is in run or crank. Quote
mediabandit Posted June 1, 2013 Author Report Posted June 1, 2013 Thanks. I went and checked the one under the hood you mentioned and figured I may as well check ALL the fuses. Not lucky enough to find a blown one. Quote
