need help with where this connector goes
I was changing spark plugs and wires on my 95 GP with the 3100 engine and I disconnected this connector as it was in my way, and for the life of me I cannot seem to find where this gets plugged into. i was in a hurry when doing it and then i went to finish the project 2 days later and I can't find where this gets connected to. It is a red plugin, first thought would be the evap purge but that has a connector on it, I think it goes somewhere on the back head but cant find where,
Anyway, this connector comes out of a big wiring harness directly behind the alternator when standing on the passenger side of vehicle. The alternator harness and a couple of other plugins also come out of this harness. Any help at all is appreciated.
I believe that's the connector for the evap purge solenoid, which is on the back of the engine underneath the area where the coils mount. Look back there.
thats what i thought to since its red in color.....but its not for the purge solenoid....this is a nightmare. i cant find where this gets connected to!
i thought about starting the car and see if ses light comes on but i dont have a scanner for the obd 1.5 system.
Edited by dardamar
I want to say it's for the Magnasteer system and is not used in 3100 cars.
Edited by ManicMechanic
Good call Manic, very possible. I always forget that these cars even had magnasteer.
thats is exactly were that wire goes. it was an option on 3100 cars.
thanks guys....but what is a magnasteer and where is it located. i am assuming its something to do with the steering
If your car had NV7/ magnasteer/ variable assist steering, that wire would go to it. since you car does not, it does it just sits limp. Yes, 3100 cars could have magnasteer... Though I have only seen two, both iirc were 96s, which includes your, Dan.
really?!!....so i just spent hours looking for a plugin that i thought i disconnected and it doesnt even exist on my car.....i feel dumb. guess thats what happens when you're in a hurry. i will put alternator back on and see what happens then and hope for no SES light.
your not the only one who was wondering were that plug went.
I should have amended my post and said not used in 1995 cars. :o
I actually found 2 1996 sedans with NV7 at the yard today.
2.25 heavy assist rack FTW!!! On the 95 CS I LQ1 swapped I enabled magnasteer and used all the parts to make it work. TGP ratio rack without the heavy feel. What's not to like?
