So i have read through the posts and i still need help, i have a worn 1990 cutlass international, i have shocks but i cant figure out the front springs to save my live. However i do have my entire rpo code list. Please help me find what springs i need
Cutlass RPO
AC3: adjuster seat, power 6 way , bucket diver
AP9: restraint cargo
AQ9: seat front bucket, pass&driver, recline
AR4: restraint system front seat auto, passive
AUO: lock control remote entry
AU3: lock side dr, electric
A31: window power operated side
A78: adjuster seat back manual pass & driver
A90: lock RR compt lid, rem cont elec release
BA6: compartment rr package shelf storage
BW2: ornamentation extra molding, body side deluxe
B 34: covering, floor mats frt carpeted inserts
B35: covering, floor mats, rr carpeted insert
B57: exterior ornamentation- deluxe
B84: ornamentation- extr molding body side
B91: ornamentation- extr molding, door edge guard colored
B94: ornamentation- extr emblem, body, var 1
CD4: wiper system, windshield pulse
C49: defogger rr window electric
C68: air cond- frt auto electronic controls
C96: lamp, intr, qtr upr, courtesy and single reading
DC4: mirror- i/s r/v tilt, dual reading lamp
DD2: mirror- i/s sunshade covered
DG7: mirror- o/s, lh&rh, rem cont, elec, painted
DOE: plant code, Doraville GA, CPC
D55: console front compt floor
D64: mirror i/s, rh, sunshade, illum
FE3: suspension system sport
GX3: ratio trans axle final drive 3.33
IL3: trim interior design (AQ9)
J65: brake system power, front and rr disc
KC4: cooling system, eng oil
KD1: cooling system trans oil
K34: cruise control automatic electronic
K60: generator 100 amp
LHO: engine gas 6 cyl, 3.1 mfi, v6
ME9: transaxle, auto 4 spd, THM 440, T4
MX0: transmission, auto provision o/d
NB2: emission system calif. requirements mandatory for calif reg
NC6: exhaust system, sporty
NP5: steering wheel, leather wrapped
NW0: wheel, 16 x 6.5 cast aluminum
N33: steering column, tilt type
PB4: lock, wheel
QGW: all tire p215/60/r16/n bl r/ pe st tl hwy
R7A: control sells item no. 26 (google)
TR9: lamp group
T96: lamp fog
UB3: cluster- inst, oil, coolant, temp, volts, trip, odom, tach
UK3: electronic system accessory control
UQ3: speaker system perf enhanced audio
US7: antenna power painted
UT6: radio, am/fm stereo, seek/scan auto rev, music search cass, equalizer, clock, ETR
U25: lamp interior rr compt courtesy
U47: lamp int engine compartment, extendable
U51: display, fuel economy, TSD info service reminder
VG8: label, notice to buyer (google)
VH9: envelope owners info manual
VK3: license plate mounting package
VY7: knob, trans cont lever, leathet
V08: cooling system, heavy duty
V73: vehicle statement, usa canada (google)
WJ7:trim override int leather trim
YF5: certification, emissions calif. (google)
Z12: package, functional appearance
Z7Q: international series model conversion opt
0HH: component, rr computer sel sup
1SC: package option 03
1SZ: package option discount
40U: exterior primary color white
6UY: component frt LH computer sel sup
7UY: component frt RH computer sel sup
71Q: molding color, med red met
78I: interior trim garnet red
783: trim combination leather, garnet red
789: seat belt color, dark garnet
tehm is ur sping cods
You have FUY coded springs. Options that do exist would be find any car in the yard that has the same code for a one spring replacement. If you are looking to change your spring rate, you could get a matched set of springs from a donor that is only slightly up the scale, for example the FUY springs.
http://www.w-body.com/oldsite/spring-codes.html
Keep in mind the following: matched springs are importants, with little exception all W's had matched front springs, except a few 3.4 dohc cars i have looked into.
thanks, so it seems like i have a pretty low spring rate in the front?
edit
Oh so i get it, the front and rear springs are matched
Can we get new spring to match or are we left with the generic ones from moog raybestos and ac delco?
I was actually speaking left and right front springs are matched. I made a reference chart for cars that i have handled, own(ed), parted, worked on:
KPB
KPA
FYB
FYA
FXX 93 int L 95 CS LQ1 L 94 Vrt L
CJK 93 int R 95 CS LQ1 R 94 Vrt R
BPY Spare L
FXT
FXS
FWW
FUZ YOUR CAR L,R
FUY 91 Vrt L,R 96 GP L
FUX My 91 international sedan L,R 93 CS Vrt L,R 95 CS SL L,R 96 GP R
FUW
FUU
FUT
?WN 93 Cs zack L,R
?WP 92 Lum L,R 94 CS S L,R
1991 Vert 3.1 FE3
0DN spring, computer select rear
6UY Frnt Left spring
7UY Frnt Right spring
1991 CS International 3.1 FE3
0HH spring, computer select rear
6UX Frnt Left spring
7UX Frnt Right spring
1993 CS International 3.1 FE3
0DM spring, computer select rear
6XX Frnt Left spring
7JK Frnt Right spring
1993 Cs sedan (Zacks dead car) 3.1 FE1
6WN Frnt Left spring
7WN Frnt Right spring
1993 CS Vert 3.1 FE3
1992 Lumina, 3.1, FE1
6WP Frnt Left spring
7WP Frnt Right spring
1994 CS S Sedan, 3100, FE1
0DK spring, computer select rear (17984228) <--- swapped to OHH
1995 CS SL Sedan, 3100(lq1 swap), FE1
1996 GP coupe, 3100 swapped to L67, FE3
ODH spring, computer select rear
1995 CS SL sedan, LQ1, FE3
1994 Vert, LQ1, FE3
Spare struts w/ bigger brakes
BPY Frnt Left spring
BPY or FXT right
Rear Leaf Spring Codes
(All first-gen exc. 95-99 Monte Carlo/Lumina)
GM Part No.
Spring
Load Rating
17988723 RHU Highest(+)
17984859 RFL
17984858 RFK
17984857 RFJ
17984856 RFH
17984855 RFF
17984232 RHN
17984231 RDN 91 Vrt 93 Vrt 94 Vrt
17984230 RDM 93 int 92 Lum
17988720 RHH 91 int 93 CsZ 95 CSSL 95 CSLQ1 YOUR CAR
17984228 RDK 94 CS S
17984227 RDJ
17984226 RDH 96 GP
17984225 RDF
17984224 RDD Lowest(-)
If you were to notice, only THREE of the cars listed have front springs that are not on the chart, but several FE1 cars use springs listed as options in the FE3 range. There is also a trend towrads stronger springs as the years pass.... I have not seen or documented a 95+ car that has springs not on the chart.
I have always gone with used, since I can find nice clean used ones when needed... Follow the rule of having them matched side by side. If you use an aftermarket spring of unknown rate, but have a second spring as part of the set, you need to use both of them.
Edited by Crazy K
p.s. you did say you need shocks, do you actually need springs? if you have good springs, you should have some that are ideal for the car you already drive. Firmer springs could make it ride like a truck........ where as a few of my cars could stand to get springs at about the same rate as your cars has because they are too soft.... If you need advice on shocks... I have plenty, just ask.
I have front shocks i havent put them in yet. I have always had monroe reflexes in the car. My rear shocks are long dead and i need to buy some. The only suspension in the back really is the moog spring helpers. So the rear end doesnt sag but it also doesnt move, handles well rides like well like ot has no suspension travel in the rear, while the front can make you sea sick, its really a rough ride. The reason im worried about the front springs is i know the shocks have been blown for a long long time. Im waiting on the last j-tool to show yup and then i can change the front shocks.
edit
and since anything is better than what my current set up is, i was looking for a little more aggresive spring for fun in the corners.
