mchill07 Posted May 12, 2013 Report Posted May 12, 2013 I got a nice gentex auto dimming mirror today. Its model 114 and has three leads. Black, L.Green and Pink/black. Anyone out there know how to hook one of these up or have a wiring diagram? Quote
RareGMFan Posted May 12, 2013 Report Posted May 12, 2013 http://www.w-body.com/showthread.php/53701-Everything-you-ever-wanted-to-know-about-auto-dimming-rear-view-mirrors Judging from the fact that black is always the ground, and green SHOULD almost always be the wire that disables the auto-dimming feature when the car is in reverse (not worth wiring in IMO), I can pretty much guarantee you the pink/black one is your +12v for the auto-dimming feature. It should be tapped into a wire or fuse that receives power with ignition or accessories on. Fun fact: If you can find one of those same mirrors from a Bonneville, the Off-Min-Max text lights up in orange. Quote
mchill07 Posted June 9, 2013 Author Report Posted June 9, 2013 Well... Today when I got in the car, The mirror didn't look right. There was a yellow line across the top and a blue line across the bottom. I guess It's gone... Quote
pshojo Posted June 9, 2013 Report Posted June 9, 2013 Pink is usually ignition, from what I've seen Quote
RareGMFan Posted June 13, 2013 Report Posted June 13, 2013 You got it to work prior to that? I've never really heard of a Gentex mirror failing. Quote
1988PhantomFE3 Posted June 13, 2013 Report Posted June 13, 2013 You got it to work prior to that? I've never really heard of a Gentex mirror failing. My Cadillac driver's side outer mirror looks horrible. Long bubble looking things that have moved all around the mirror, gross yellow/orange tint too. It comes on when we flip the switch on the interior rear view mirrow, combined with the switch for digital compus read out. Anyone know how to fixs these things? Thanks! Quote
mchill07 Posted June 13, 2013 Author Report Posted June 13, 2013 My problem went away. Was prolly something to do with how hot it was. My mirror has a slight gold tint to it. is from a 94' Eldorado Quote
ManicMechanic Posted June 14, 2013 Report Posted June 14, 2013 My Cadillac driver's side outer mirror looks horrible. Long bubble looking things that have moved all around the mirror, gross yellow/orange tint too. It comes on when we flip the switch on the interior rear view mirrow, combined with the switch for digital compus read out. Anyone know how to fixs these things? Thanks! Likely needs a new mirror. Quote
RareGMFan Posted June 14, 2013 Report Posted June 14, 2013 My Cadillac driver's side outer mirror looks horrible. Long bubble looking things that have moved all around the mirror, gross yellow/orange tint too. It comes on when we flip the switch on the interior rear view mirrow, combined with the switch for digital compus read out. Anyone know how to fixs these things? As Manic said, there's no fixing these mirrors once the electrochromic element goes bad. Just have to replace the glass/mirror. The side mirrors are the only Gentex I've seen fail. I don't know why. Maybe because they're exposed to the elements more. My problem went away. Was prolly something to do with how hot it was. My mirror has a slight gold tint to it. is from a 94' Eldorado That's how all those early self-dimming Gentex mirrors were. It's normal. They didn't get to clear glass till the late '90s. Too bad you couldn't find one out of a '92 + Bonneville. The buttons light up orange on those. Quote
mchill07 Posted June 14, 2013 Author Report Posted June 14, 2013 I've looked in multiple Bonneville's and so far they have only been standard mirrors. must have been a rare option, like SSEI only. The SSE I found was loaded except the mirror and hud. Quote
RareGMFan Posted June 14, 2013 Report Posted June 14, 2013 I'm pretty sure it was standard in the SSEi. Not positive if it was an option or not on the SSE, but I'm thinking so because I doubt that I found all the ones I have from SSEis alone. Quote
1988PhantomFE3 Posted June 14, 2013 Report Posted June 14, 2013 Wow, I didn't realize the morrors were so different, but could be use on my caddy. I'm going to look around up here for these models in the recycle yards. Quote
RareGMFan Posted June 14, 2013 Report Posted June 14, 2013 There are many different variations, but the mounting brackets are usually universal. Once in a while, there will be a variant (usually on imports), but otherwise, they're mostly interchangeable as long as you have/are willing to do the wiring. Quote
ManicMechanic Posted June 14, 2013 Report Posted June 14, 2013 Wait Ed, you need a side view or rear view mirror? Quote
