GreenBeast GrandPrix Posted May 10, 2013 Report Posted May 10, 2013 My 1994 Pontiac Grand Prix SE has a mono leaf rear suspension. I would like to lower it but that involves swaping the rear end. Do the bolt patterens between the two rear ends match? I would like to just swap the rear ends without having to drill and tap new holes. Input is greatly apperciated!!!!!! Quote
GreenBeast GrandPrix Posted May 10, 2013 Author Report Posted May 10, 2013 Okay but I still have to do something about the mono spring Coilovers Quote
skitchin Posted May 11, 2013 Report Posted May 11, 2013 Follow my adventure from monoleaf to coilovers. Not exactly a how to thread, but you should be able to find all the links you need http://www.w-body.com/showthread.php/52819-1995-GP-SE-Rear-suspension Quote
Psych0matt Posted May 12, 2013 Report Posted May 12, 2013 coilovers with 2nd gen knuckles. Not very hard at all if you have a few tools, some knowledge, and perhaps a Bxx Quote
raemore Posted May 22, 2013 Report Posted May 22, 2013 My 1994 Pontiac Grand Prix SE has a mono leaf rear suspension. I would like to lower it but that involves swaping the rear end. Do the bolt patterens between the two rear ends match? I would like to just swap the rear ends without having to drill and tap new holes. Input is greatly apperciated!!!!!! btw .....do you know if 94 grand prix suspension same as 94 cutlass supreme or grand am? Quote
jman093 Posted May 22, 2013 Report Posted May 22, 2013 btw .....do you know if 94 grand prix suspension same as 94 cutlass supreme or grand am? 1st gen W-body cars are all the same suspension: 1988-1996 Grand Prix 1988-1997 Cutlass Supreme 1990-1994 Lumina 1988-1996 Regal Quote
Imp558 Posted June 13, 2013 Report Posted June 13, 2013 What's the benefit of the 2nd Gen Knuckles? My car already has disc brakes back there. I'd like to use 2nd Gen Lateral links to get the stance out a bit, but I'm really curious if the 2nd Gen cradle is compatible, like to get a cradle so I can have everything prepped and more or less ready to slide into the car when I lay it up again. Quote
jman093 Posted June 13, 2013 Report Posted June 13, 2013 What's the benefit of the 2nd Gen Knuckles? My car already has disc brakes back there. I'd like to use 2nd Gen Lateral links to get the stance out a bit, but I'm really curious if the 2nd Gen cradle is compatible, like to get a cradle so I can have everything prepped and more or less ready to slide into the car when I lay it up again. The knuckles are aluminum. You can't swap the cradles. Just install the links on your car. Quote
Imp558 Posted June 13, 2013 Report Posted June 13, 2013 Cool, I'll pick up a first gen cradle, just thought that if the 2nd gen was the same I'd get one that was 5 years newer Quote
