Sometime soon I will be taking care of the no tcc in the regal... I believe its the valve body as the toccata solenoid was previously replaced... I have a couple options, I can take it to the trans shop and have them work on it... I can attempt the repair myself, however I do not have much experience tearing into transmissions, or install the same shift kit and HD diff into an 18k mile transmission that I bought a while back, which is currently in Canada... looking for your individual thoughts on the situation... the current trans has around 140k but shifts flawlessly with the exception of no tcc... both trannies are 3.29 geared trannies, the one in it is a 98 mc z34 trans and the low mile one is from an 02 gpgt... what would you do to fix this?
I'd do the trans swap. I'm assuming you can do it yourself.
Just thinkin you might end up with more issues after the repair
on the current trans.
