tgpguy21 Posted November 6, 2003 Report Posted November 6, 2003 I have a 1994 gp se, that has the b4u package on it. i want to take out the fog lights on the bottom and replace both of them with K&N cone filters that will run throught my stock air box. i already have it planned out on how to do it, but would anyone see a problem with me doing this. i have a plan on how to cover them when its raining so thats already taken care of. do you guys think this would be a pretty good idea for a cold air intake system???? any help would be much appreciated....... Quote
gp90se Posted November 6, 2003 Report Posted November 6, 2003 Ram air idea....if ya can route it and find k&n filters to fit. interesting to see how it comes out. -Jeff Quote
Rob95CS Posted November 6, 2003 Report Posted November 6, 2003 Sounds like a great idea... Ram air would net you an easy 5+ HP. I really don't think rain would be a big problem either with this setup, because the tubes running from the filters are going to have to go UP from the fog light area to the intake box. Correct me if I'm wrong. Quote
MaroonRegal Posted November 6, 2003 Report Posted November 6, 2003 Sounds like a great idea... Ram air would net you an easy 5+ HP. I really don't think rain would be a big problem either with this setup, because the tubes running from the filters are going to have to go UP from the fog light area to the intake box. Correct me if I'm wrong. You're right that the water's less likely to get to the engine, but it could fuck up the two cone filters. What about puddles, tgpguy21? Quote
J Posted November 6, 2003 Report Posted November 6, 2003 you guys keep sayin RAM AIR, it'd only be a open element filter, ram air doesn't really work until like 60 mph anyway. I'd be careful if i were you to do that kind of mod, the bottomes of the filters would be caked with mud, gravel. bugs. and if it does rain then the rain can still get in from the ground. just kep that in mind, good luck with it. Jay Quote
joey b Posted November 7, 2003 Report Posted November 7, 2003 run your car at high RPM and tell me how hard it pulls air. I'd do it anyway. The effects of ram air would be about nil though because of all the bends that would be needed. And remember how you clean a K&N. Water is going to wash the oil off of the filter. Quote
kfahn Posted November 7, 2003 Report Posted November 7, 2003 use a dry charger, and you should be ok Check them out here Quote
