redgrandprix Posted March 31, 2013 Report Posted March 31, 2013 (edited) I'm not an audiophile so i don't quite understand how these work. would these be ok for plug and play on an aftermarket headunit? would these be any better than say alpine type R's? http://www.crutchfield.com/p_158GS6920/Sony-XS-GS6920.html?tp=105#details-tab Edited March 31, 2013 by redgrandprix Quote
madbrad Posted March 31, 2013 Report Posted March 31, 2013 (edited) All(except specialty) aftermarket speakers, including these, have an impedance of 4 ohms. All(except specialty) aftermarket head units call for 4 ohm speakers. That is, it wants to see 4 ohms at each corner, however you acheive that. So if you already have an aftermarket head unit, yes they work. I don't know how good or bad that is compared to other makes, but in general people feel Sony is cheapo whereas Alpine is much better. But we can't all afford the very greatest speakers. What speakers are in there now? I'm guessing these Sonys would be better than that. many factory systems use strange impedances. Their speakers are of strange impedances to match what the strange head units call for. If you have aftermarket speakers with a factory head unit, or vice-versa, you're mismatching impedances and that can become an issue. too high impedance speakers make it too quiet, and too low impedance speakers can give you clipping and/or risk damaging the amplifier in the head unit. Edited March 31, 2013 by madbrad Quote
RPE1992GPSE Posted March 31, 2013 Report Posted March 31, 2013 The impedance of speakers will only cause differences in volume with all other things being equal. Speaker sensitivities and frequency response curves are far more telling of a speaker's relative volume level than merely looking at the ohm rating on the back of the magnet. Quote
E_RICE Posted April 21, 2013 Report Posted April 21, 2013 Me personally would go with infinity kappas... I have them and they are richer and warmer than alpine type r's especially when you put an amp on them... they are also 2 ohm speakers which will give you more power out of your amp and if you wire them to your head-unit they are safe and will not cause any problem with it... I have 5.25 components up front and the 2 way 6x9's in the rear powered by a mtx td series 4 channel. Quote
Andrew Posted April 22, 2013 Report Posted April 22, 2013 holy crap those are expensive Sonys. I have to agree with the newb and say Infinity Kappas are awesome. http://www.onlinecarstereo.com has much better prices! Quote
redgrandprix Posted April 22, 2013 Author Report Posted April 22, 2013 what i'm trying to do is get the most bass/ best sound from a system with no amp, i particulary don't want to go through the process of hooking up an amp because if i'm going to do that i might as well get a sub but now i'm kinda liking jbl's but still up in the air Quote
Andrew Posted April 24, 2013 Report Posted April 24, 2013 You will be disappointed with whatever you purchase then. Mids, aka full range speakers, arent designed for much bass. Couple that with your head units low power output, likely somewhere in the 14-30 watts RMS range, and you are underpowering your fancy new mids. Quote
redgrandprix Posted April 24, 2013 Author Report Posted April 24, 2013 You will be disappointed with whatever you purchase then. Mids, aka full range speakers, arent designed for much bass. Couple that with your head units low power output, likely somewhere in the 14-30 watts RMS range, and you are underpowering your fancy new mids. Thank you, that is what i was wondering, i'm not sure I would be dissappointed, i've got some OLD sony xplods or atleast they don't make them in the same style and they sound pretty good just not as good as my friends cars that are newer, i want the bass thats being played to be a little cleaner, not my cousin's jl subs that make my entire body vibrate. Quote
will_s95 Posted May 1, 2013 Report Posted May 1, 2013 (edited) If you're looking for bass response, even though you won't get much out of a 6x9, but if your going to spend 200 on a set of coaxials, this is what you want. http://www.crutchfield.com/p_500SPR69/Alpine-SPR-69.html If you choose to invest in a 4 channel amp, then your speakers will really shine. Edited May 1, 2013 by will_s95 Quote
