Reride Posted March 23, 2013 Report Posted March 23, 2013 I just picked up a Digital UB3 from a '89 CS for my '92 CS. How would I test my prize find to see if it is a prize. I got the pigtail as well. Quote
RobertISaar Posted March 23, 2013 Report Posted March 23, 2013 depends on how much you want to test. with i think 3 wires, you can do the boot-up procedure, a lot more for most of the indicators. to test the tach and redline functions, you would need to simulate the datastream from the ECM, that's the only real complicated portion. the MPH portion can be verified by just tapping the VSS wire to a ground wire quickly(a couple of times a second will show ~5MPH). Quote
94 olds vert Posted March 23, 2013 Report Posted March 23, 2013 (edited) Take a look at this thread. I have bench tested a digi UB3 before its not hard. http://www.w-body.com/showthread.php/48433-Bench-powering-CS-UB3-digital-cluster Here is a video of my cluster being tested. Edited March 24, 2013 by 94 olds vert Quote
Reride Posted March 24, 2013 Author Report Posted March 24, 2013 Thanks Nate and Robert:thumbsup:, I checked out the thread you sent & got pin-outs but your you-tube video would not play:shrug:...will try again later. Steve Quote
94 olds vert Posted March 24, 2013 Report Posted March 24, 2013 I went back and fixed the link in my post. Hopefully it will work for you now. Quote
Reride Posted March 24, 2013 Author Report Posted March 24, 2013 (edited) After comparing the pin-outs from the link you provided (for 1990 model) & they are the same w/one exception, mine doesn't have the GRY/WHT wire in C5. So the '89 car my cluster came out of must not have had ABS & will need to be added for my '92. Since I'm in my mid-sixties & my fingers aren't as flexible as they once were I will go with an adapter to connect to the harness, though repining would be a lot cleaner install. Now on to the actual testing. I will post results later. P.S. Nate, the you-tube video works now, Thanks. Edited March 24, 2013 by Reride Quote
Reride Posted March 24, 2013 Author Report Posted March 24, 2013 I just finished testing my digi UB3. All seems to work. I tried tapping the orange VSS wire (C13) to ground as Robert suggested & got it to read 2 mph, but no tach reading. I tried it a second time & got nothing, hope I didn't screw something up! The oil pressure & fuel gauges were pegged ( I assume because of no sender signal.) The temp gauge increased when power was applied and volt meter increased when more amperage was applied. Turn signals, high beam light, E/M, trip & reset bottoms, & all idiot lights worked. Quote
GnatGoSplat Posted March 27, 2013 Report Posted March 27, 2013 The tach (and redline bar) gets its input from ALDL serial data, so the only way to test that is to connect the ALDL wire to an ECM or something that simulates an ECM. Chances are, since everything else works, the tach is most likely fine. Quote
Reride Posted March 29, 2013 Author Report Posted March 29, 2013 I know that I need to replace the senders for oil pressure & Temp will I need to add any wiring for them to work on the cluster? Also, do I need to buy senders for a '89 or '92 car. Quote
