daledubourg Posted March 19, 2013 Report Posted March 19, 2013 hi everyone I have a 94 prix with quite a stiff bumpy rear end. I've replaced the struts and also added the moog white pad to the monospring. my ride has gotten better but it's still stiff and the drivers side is still lower than the passengers. I'm pretty sure now I need to look at replacing the leaf spring itself but wanted to get a second opinion. thanks for any help Quote
Timm Posted March 19, 2013 Report Posted March 19, 2013 You're on the right track. You'll need to replace the spring itself. Not a terrible job, just a lot of wiggling the spring around and being careful to make sure to properly relieve the pressure. Also, there's a post on here somewhere with the w-body spring rate codes as far as what's softer or stiffer. I think there's like 10 different springs used? Really any one of them should work, it may just ride more like a Regal, or more like a GTP. Quote
daledubourg Posted March 19, 2013 Author Report Posted March 19, 2013 right on thank you im gonna replace the front struts here in a week or two maybe that will level the car out but im pretty sure more than likley im looking at that mono spring the drivers side rear had a blown strut for maybe more than a year before i changed it Quote
sjs1986 Posted March 25, 2013 Report Posted March 25, 2013 Hi, I have to change the white pads on my 96 cuttlass supreme 3100 and possibly change the spring itself. Is there a special tool to be used for this? Quote
GOT2B GM Posted March 25, 2013 Report Posted March 25, 2013 Hi, I have to change the white pads on my 96 cuttlass supreme 3100 and possibly change the spring itself. Is there a special tool to be used for this? I have a good used spring available if you need one. Quote
sjs1986 Posted March 25, 2013 Report Posted March 25, 2013 I have a good used spring available if you need one. Thanks Matt but I am in Vancouver. Can you rent those? Quote
GOT2B GM Posted March 25, 2013 Report Posted March 25, 2013 I have one.... would be expensive to ship there and back..... Quote
Crazy K Posted March 25, 2013 Report Posted March 25, 2013 I've done it without a tool, but I lowered the struts down much further than normal for the spring to slip in... done by unhooking the tops of the struts from the body. Quote
mhildebrand Posted March 28, 2013 Report Posted March 28, 2013 (edited) Hi, I have to change the white pads on my 96 cuttlass supreme 3100 and possibly change the spring itself. Is there a special tool to be used for this? http://www.w-body.com/showthread.php/21004-Monoleaf-Pad-Thread-(Part-Number-and-HowTo-Inside)/page4 Schurkey has how to make a spring compressor here if you have tools to do so. I made one out of thin quick strut scrap that we wad at work. I just had to add a piece of 1/8" to the piece that pushes on the spring. Lowes had 1/2" bolts that are threaded all the way. I replaced mine with the rubber pads like what was OEM. Can't recall where I got them, either O'Reilly's or Advanced. Came with epoxy to stick them to the spring. Edited March 28, 2013 by mhildebrand Quote
