RobertISaar Posted March 22, 2013 Report Posted March 22, 2013 P0321 would be the 24X crank sensor. the one that's basically on the balancer/damper. Quote
95LQ1VERT Posted March 22, 2013 Author Report Posted March 22, 2013 Thanks, it would have taken me a while to figure that one out on my own. Quote
95LQ1VERT Posted March 30, 2013 Author Report Posted March 30, 2013 Replaced the 24x sensor last night, what joy, anyways I still am having an intermittent missfire at idle. Scantool is showing bad cyl #6 and code p1640 (QDM) A. Also in the data stream every so often it shows "QUAD DRIVER 1: BAD" but sometimes it says its OK? Getting pretty damn irrated at this SOB EDIT: My Hanes manual says nothing about he DTC im having. Quote
95LQ1VERT Posted March 31, 2013 Author Report Posted March 31, 2013 Went ahead and replaced the evaporative purge solenoid, codes are no longer present. Missfire is still F*cking there. Im guessing I have a burnt valve or a plugged injector:shrug: Quote
Galaxie500XL Posted March 31, 2013 Report Posted March 31, 2013 I had to do the same to mine when I first bought it...apparently a fairly common problem with the purge solenoid. Most frustrating was I couldn't find any detail WHAT devices the Quad driver ran.. Sorry to hear about the misfire..I'm assuming you've already tried a different coil, and ICM? Went ahead and replaced the evaporative purge solenoid, codes are no longer present. Missfire is still F*cking there. Im guessing I have a burnt valve or a plugged injector:shrug: Quote
95LQ1VERT Posted March 31, 2013 Author Report Posted March 31, 2013 I had to do the same to mine when I first bought it...apparently a fairly common problem with the purge solenoid. Most frustrating was I couldn't find any detail WHAT devices the Quad driver ran.. Sorry to hear about the misfire..I'm assuming you've already tried a different coil, and ICM? Not yet I havent, dont really know how to remove them as I can't see the bolts. Quote
AL Posted March 31, 2013 Report Posted March 31, 2013 5.5mm deep socket, the bolts are in the middle of where the plug wires attach Quote
95LQ1VERT Posted March 31, 2013 Author Report Posted March 31, 2013 Thank you Al! Now I just have to get the parts lined up and find some time. Quote
Galaxie500XL Posted April 1, 2013 Report Posted April 1, 2013 I'd recommend a patient friend when you go to reinstall the parts. The six bolts that hold the coils in place also hold the ICM in place..when you go to reassemble, it can be rather challenging to hold the ICM, and the first coil in place, while simultaneously starting the bolts in the first coil. What I did was remove the cooling fan to gain space, then started a couple of bolts on opposite corners of the ICM, starting with the middle coil as my first to install. Careful not to overtighten the coils, please don't ask me how I learned that lesson. BTW, 3400's use the EXACT same coil and ICM as the LQ1...my current set came from an Intrigue..got the entire set for about $40.00 at the junkyard. MUCH cheaper than buying new, and since the 3400 coils sit on top of the motor, much easier than other 60 degree V-6's to harvest. Thank you Al! Now I just have to get the parts lined up and find some time. Quote
95LQ1VERT Posted April 1, 2013 Author Report Posted April 1, 2013 Thanks for the tip Dan, There are plenty 3400 powered cars at the local upull it. All I need for tools to take to the JY is a 5.5mm deep socket, maybe an extension and a ratchet right? Quote
Galaxie500XL Posted April 1, 2013 Report Posted April 1, 2013 You could do it that way, but I took the entire bracket, and left the coils and ICM attached to the bracket...the junkyard charged me less that way..they didn't seem to realize (or care) that I was also buying the ICM..besides, that made it less likely I'd damage the parts before I installed them. Thanks for the tip Dan, There are plenty 3400 powered cars at the local upull it. All I need for tools to take to the JY is a 5.5mm deep socket, maybe an extension and a ratchet right? Quote
Galaxie500XL Posted April 4, 2013 Report Posted April 4, 2013 Um...make that an ACHIEVA I got the coils and ICM from...the Intrigue didn't get the 3400... Quote
Galaxie500XL Posted April 5, 2013 Report Posted April 5, 2013 Well, it was definitely a newer Oldsmobile...may have been a 3100, rather than a 3400.. Quote
Galaxie500XL Posted April 5, 2013 Report Posted April 5, 2013 http://www.w-body.com/showthread.php/49131-LQ1-Ignition-parts-interchange?highlight=ignition+interchange I found the old post where i did that...I was confused on what car I got it from then, as well...turns out ALL 60* V-6 engines through 2004 used the same ICM and coil... Quote
95LQ1VERT Posted April 5, 2013 Author Report Posted April 5, 2013 Okay well good! Now we all know that we can use the same ICM and coils from majority of the 60* 6! Galaxie500XL did you remove both cooling fans or what? And when you did the coils/ICM, did you access them from the top or bottom? Quote
Galaxie500XL Posted April 5, 2013 Report Posted April 5, 2013 I recall only removing the driver's side cooling fan, and I accessed them from the top. Way too much crap in the general area to get a good shot at them from the bottom. I used a helper (my son) to hold the ICM in place while I got a couple of screws started on the corners, then mounted the center coil first. After the first one is (finally) mounted, the rest are pretty easy. Okay well good! Now we all know that we can use the same ICM and coils from majority of the 60* 6! Galaxie500XL did you remove both cooling fans or what? And when you did the coils/ICM, did you access them from the top or bottom? Quote
95LQ1VERT Posted April 12, 2013 Author Report Posted April 12, 2013 Im kind of skeptical of this misfire being coil/ICM related considering the fact that the miss is @ idle and not under load and its happening on just cylinder #6 (from what my scan tool is telling me). Unless a weak coil would cause this? My ideas on why its missing: - *maybe* dirty fuel injector - *maybe* cam timing is wrong - *maybe* weak coil - *maybe* ICM - *maybe* DTC p1640 - I will scan again after work to be sure if I still have this code Quote
95LQ1VERT Posted April 13, 2013 Author Report Posted April 13, 2013 From what I understand, In my haynes manual electrical diagram it shows "canister purge sol ctrl" @ the PCM and it has a line that goes evap emis canister purge solenoid then it intersects into the EGR asembly for solenoids A B and C then returns to the PCM, power steering pressure switch which returns to the PCM, and the engine emis fuse 15a in the under hood electrical center #1. What im getting at is that I dont have the variable orifice powersteering anymore, just a basic unit. Could this be my DTC p1640 im getting? Quote
RobertISaar Posted April 13, 2013 Report Posted April 13, 2013 variable orifice power steering is controlled by the ABS module, not the PCM, so that's not causing it. Quote
Galaxie500XL Posted April 14, 2013 Report Posted April 14, 2013 I've been reluctant to mention, a burned valve will cause similar symptoms...usually, you'll find that by doing a compression test... Im kind of skeptical of this misfire being coil/ICM related considering the fact that the miss is @ idle and not under load and its happening on just cylinder #6 (from what my scan tool is telling me). Unless a weak coil would cause this? My ideas on why its missing: - *maybe* dirty fuel injector - *maybe* cam timing is wrong - *maybe* weak coil - *maybe* ICM - *maybe* DTC p1640 - I will scan again after work to be sure if I still have this code Quote
Schurkey Posted April 14, 2013 Report Posted April 14, 2013 The exhaust valves of my '93 Lumina looked terrible when I yanked the head to replace the head gasket. So did the exhaust valves of the spare pair of heads I bought. After grinding, and before. All 24 exhaust valves looked like this: The exhaust seats, on the other hand, looked wonderful. Quote
95LQ1VERT Posted April 15, 2013 Author Report Posted April 15, 2013 Thanks for the reference Schurkey, This week when I get paid I'll have to run a compression test. But im wondering how in the world would I be able to check the rear banks compression? Could I do the front three and get the numbers or do I need all six? Quote
Schurkey Posted April 15, 2013 Report Posted April 15, 2013 Thanks for the reference Schurkey, This week when I get paid I'll have to run a compression test. But im wondering how in the world would I be able to check the rear banks compression? Could I do the front three and get the numbers or do I need all six? You'll want all six. OTC and others sell a compression tester extension for recessed spark plug holes. The OTC version is imported from China or Korea--I forget which. http://www.amazon.com/COMPRESSION-TSTR-DP-WELL-CONNECTOR/dp/B00C7JWV6I/ref=sr_1_38?ie=UTF8&qid=1366041056&sr=8-38&keywords=OTC+compression I don't remember paying anywhere near $50 for mine, though. Shop around, I bet you can find 'em for half that much. [EDIT} http://www.amazon.com/OTC-5603-Compression-Tester-Connector/dp/B000R5ARJ2/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1366041173&sr=1-1-catcorr&keywords=OTC+5603 Quote
