J.r. Patton Posted February 23, 2013 Report Share Posted February 23, 2013 Does anyone know if the 95 cutlass convertible has the wiring to switch to a power antenna? Mine was a fixed mast, but thanks to the mechanic its broke. I was wondering if I could switch it to a power antenna without have to wire it up myself? Quote Link to comment Share on other sites More sharing options...
jackhartjr Posted February 24, 2013 Report Share Posted February 24, 2013 My first guess is that it probably does, the wiring is probably back there, if the option was for a power antenna, then it was hooked up. Just a guess. Jack Quote Link to comment Share on other sites More sharing options...
94 olds vert Posted February 24, 2013 Report Share Posted February 24, 2013 I'd look at the wiring harness on the right side of the trunk. If there is an unused connector other than the one to ground out the RKE box for the key fobs then it would a plug and play situation. Quote Link to comment Share on other sites More sharing options...
J.r. Patton Posted February 24, 2013 Author Report Share Posted February 24, 2013 Well for sure it has the Key Fob ground! Haven't seen another one.. So I guess Ill be sticking with the fixed mast. Quote Link to comment Share on other sites More sharing options...
