The Jr Sprung a leak.
Seems to be a common part to go however. Looks like one or both of my Trans cooler lines are leaking.
Does anyone have the part #'s handy to replace these guys?
Go figure i notice a leak right out of winter storage lol.
I dealt with the same thing on the last 99 regal I had. You're going to need the hoses and the connectors for the radiator. On these newer cars the pieces are separate. You put the connector into the radiator first, and then the hose snaps into it. It's a pita if you're not aware of it before hand. Rockauto has them and you should be able to find them at autozone too.
You might be able to get away with using the radiator connectors you already have if they're not rusted to pieces already though.
Those are leaking on my car as well.. Luckily mine isn't bad enough to get on the ground (yet), but my hoses look like yours do..
yeah mine was pissing out onto the garage floor today. otherwise i would have gone for a drive.
Rock Auto shows 2 versions. Mine should be the new versions?
Delco # 15264588 and 15264589 for the lines.
What part is for the rad connector? Anyone know that off hand?
I can't say for sure, looks like it depends on when your car rolled off the assembly line since they updated the design mid-year. You should be able to find that info on your door sticker though.
