mchill07 Posted February 10, 2013 Report Posted February 10, 2013 I bought a 95 GP today and found that the gear shifter can be moved out of park W/o the key or in the off position, When I turn the key to ACC or ON it locks until you place your foot on the brake. This cant be right... What kind of problem is this? Quote
95 vert Posted February 10, 2013 Report Posted February 10, 2013 Sounds like the shift lock cable is out of adjustment, disconnected or broken. Runs from the shifter to the column. Quote
Crazy K Posted February 11, 2013 Report Posted February 11, 2013 I concur with the shift lock cable, it runs from the ignition switch on top of the column to the shifter in the console. The lock until brake release is a secondary electric solenoid. remove the shift knob by taking the "staple" on it's front out. then tap it by hand till it comes up. Next pull the shifter tray and cupholders out, and you'll be at the shifter. Good chance the cable end is broken, which mean you need a replacement cable. I've seen this before, and likely it was tampering that damaged it. I have a shift lock cable that fits you car if you are in need. PM me if you need. Quote
mchill07 Posted February 14, 2013 Author Report Posted February 14, 2013 I've got the center console apart to look at the shifter mech. I dont see where any adjustments to the cable can be made. Will I need to dismantle the steering column to find the other end? The brake release portion works, its just not locked in the key off position with the key removed. So basically its fine in all other positions just not off. Quote
95 vert Posted February 15, 2013 Report Posted February 15, 2013 Remove the knee bolster and small metal panel to access where the cable hooks at the steering column. I can't remember exactly how it's set up but you should be able to figure it out just looking at it. Quote
Crazy K Posted February 15, 2013 Report Posted February 15, 2013 remove the plastic panel and metal panel under the column. back the two bolts out at the base of the column halfway. remove the two bolts at the top next and let the column drop (push seat back!) the ignition switch is where the cable attaches, and it is on top of the column near it's base... see if the cable is attached and even functioning. Quote
mchill07 Posted February 16, 2013 Author Report Posted February 16, 2013 I'm guessing it really is out of adjustment because now when I turn the key to ACC nothing happens, no ACC power, and the key springs back to the off position. Quote
