Reride Posted February 9, 2013 Report Posted February 9, 2013 Do I need to have my '92 CS vert on level ground to change the STB as you would if you were changing the front struts? Quote
19Cutlass94 Posted February 10, 2013 Report Posted February 10, 2013 front wheels must be on the ground Quote
ScoobyDoo82 Posted February 10, 2013 Report Posted February 10, 2013 You might have to bounce the car a bit to make it fit, its shocking how much those strut towers move w/o a brace. Quote
Reride Posted February 10, 2013 Author Report Posted February 10, 2013 Well, I made the wife mad by putting her truck out in the weather to get flat ground, But I got the LQ1 STB put on my '92 3.1 CS vert today. It was very easy to. I didn't lift the car off the ground, just unbolted and replaced. The only issue which is very slight is the trans dipstick is making contact with the STB. But I can live with that. Thanks everyone for the suggestions. Steve Quote
white4d96 Posted February 10, 2013 Report Posted February 10, 2013 FWIW On my GP I have to lift one corner of the car slightly to get the STB to pop into place. Quote
Reride Posted February 14, 2013 Author Report Posted February 14, 2013 The only thing I needed to make the STB go over the studs was the palm of my hand. One good hit and it went over quite easy. Quote
Euro Posted February 14, 2013 Report Posted February 14, 2013 I remember having to bang the fuck out of the LQ1 bar to put it on my Lumina. Couple hard rubber mallet smacks and it was good to go. It came off easier than putting it on Quote
