redgrandprix Posted February 6, 2013 Report Posted February 6, 2013 i have sony xplod 6x9's rated to 350 watts and they sound pretty good but they are a little to big for the stock speaker locations in that only 3 out of 4 bolts line up so they rattle a little sometimes and my friend said if i were to make boxes for them or get some that they would have more bass and wouldn't rattle, just looking for some thoughts Quote
white4d96 Posted February 6, 2013 Report Posted February 6, 2013 I wouldn't bother. Do you have pics of how they don't fit? I have some huge VIBE 6x9's in my rear deck and they fit no problems. Are you using the factory speaker shroud? Quote
RobertISaar Posted February 6, 2013 Report Posted February 6, 2013 i've stuck quite a few aftermarket 6X9s in the rear decks of W-bodies without issues before.... i'd say that you have a "defective" speaker or the mounting plate was made oddly... slot the hole/reposition the speaker so that all 4 screws will engage. Quote
GaPrix Posted February 6, 2013 Report Posted February 6, 2013 I wouldn't bother. Do you have pics of how they don't fit? I have some huge VIBE 6x9's in my rear deck and they fit no problems. Are you using the factory speaker shroud? What Vibes? I have a the blackdeaths in rear deck, had to box them. "Spaces' up front. On topic - you could probably slot or drill the holes like said that should help reduce the rattle/vibrations. Quote
white4d96 Posted February 6, 2013 Report Posted February 6, 2013 What Vibes? I have a the blackdeaths in rear deck, had to box them. "Spaces' up front. On topic - you could probably slot or drill the holes like said that should help reduce the rattle/vibrations. Aren't the black death's square or something like that? I think I have the blackairs. Quote
RPE1992GPSE Posted February 6, 2013 Report Posted February 6, 2013 I agree with everyone else. I was able to fit a pair of Sony 6x9s in my rear deck using the factory adapters. They fit - you just can't tighten each screw all the way down one at a time. Tighten each screw about 1/4 to 1/3 of the way down and proceed to tighten each screw about 1/4 of the way further, doing each a little at a time and in a "star" pattern. Are you using the factory head unit? If you are using a stronger aftermarket unit, your rear speakers will likely rattle if you use the factory adapters, even if you tighten all the screws properly. You're going to get adapter-to-deck resonance if you're pushing enough wattage through them unless you use some sort of dampening material. A box probably will not make a big difference in bass response, and it won't make any difference at all with rattling. Quote
19Cutlass94 Posted February 7, 2013 Report Posted February 7, 2013 Box wont make a difference unless you have an amp on the speakers, and even then, 6x9's dont handle that much power. I dont even have any rear speakers in my car. Just a component set up front and a single 12" sealed in the truck. And even then I hardly listen to it. Quote
GaPrix Posted February 7, 2013 Report Posted February 7, 2013 Aren't the black death's square or something like that? I think I have the blackairs. Yeah they're ridiculously massive, 6x9 subwoofers. Quote
redgrandprix Posted February 7, 2013 Author Report Posted February 7, 2013 reason i ask is because i pushed up on the speakers from the trunk while they were playing and it stopped the rattling so i popped off the shrouds to tighten them and noticed there were only 3 bolts in each speaker, and i have a JVC head unit 4x50w typical aftermarket head unit, http://www.bestbuy.com/site/JVC+-+50W+x+4+MOSFET+Apple%26%23174%3B+iPod%26%23174%3B-Ready+Digital+Media+Receiver/4707085.p?id=1218512775506&skuId=4707085 Quote
killa cam Posted February 7, 2013 Report Posted February 7, 2013 try putting some modeling clay between your speaker, the adapter, and the rear shelf. you could also dynamat the rear shelf as well. http://www.amazon.com/Prang-Modeling-Colored-Blocks-Pounds/dp/B001AYYBEG/ref=sr_1_1?ie=UTF8&qid=1360259757&sr=8-1&keywords=modeling+clay Quote
RPE1992GPSE Posted February 7, 2013 Report Posted February 7, 2013 reason i ask is because i pushed up on the speakers from the trunk while they were playing and it stopped the rattling so i popped off the shrouds to tighten them and noticed there were only 3 bolts in each speaker, and i have a JVC head unit 4x50w typical aftermarket head unit, http://www.bestbuy.com/site/JVC+-+50W+x+4+MOSFET+Apple%26%23174%3B+iPod%26%23174%3B-Ready+Digital+Media+Receiver/4707085.p?id=1218512775506&skuId=4707085 Pushing up on the speaker from underneath dampened the vibration you were hearing. I'm not sure how a box would achieve the same effect. Quote
