Cygnus Posted February 4, 2013 Report Posted February 4, 2013 (edited) So, doors not opening from the outside as usual during the winter. We had a large snowfall and it covered my car. Since it got cold I have been leaving my door open a crack or the window down. Well, the weight of the snow shut my door enough to get to the first click. Now, the nature of what I ask my be a little un-ethical. I need to know how to break in to my car with out breaking my car. Maybe force the window down or something that can get inside and get the mechanism to work. I have a brick on stand by...... Edit: It's the car in my sig. Edited February 4, 2013 by Cygnus Quote
j_mezz Posted February 5, 2013 Report Posted February 5, 2013 Do GP's have a pass-through? Maybe you get in through the trunk and then through there? Quote
Psych0matt Posted February 5, 2013 Report Posted February 5, 2013 This may not help you get in, but for future precaution, when mine broke I tied a shoe string to the inside handle and would shut it in the door (so I could pull the inside handle with the string), or you could maybe leave it in the window and leave the window rolled down just a tiny bit so you could pull it Quote
Schurkey Posted February 5, 2013 Report Posted February 5, 2013 So, doors not opening from the outside as usual during the winter. We had a large snowfall and it covered my car. Since it got cold I have been leaving my door open a crack or the window down. Well, the weight of the snow shut my door enough to get to the first click. Now, the nature of what I ask my be a little un-ethical. I need to know how to break in to my car with out breaking my car. Maybe force the window down or something that can get inside and get the mechanism to work. I have a brick on stand by...... Edit: It's the car in my sig. So you want us to tell you how to break into a vehicle? Nice try. Not going there. How about you take the car to a shop--or pull the door panel yourself--and FIX THE MECHANISM? Then you won't need instructions on how to break in. Don't forget to lightly lube the weatherstrip so it doesn't freeze to the metal of the body. Quote
Cygnus Posted February 5, 2013 Author Report Posted February 5, 2013 both doors don't work? Correct. Passenger never works from outside and the driver's side doesn't like to work in winter. Quote
Cygnus Posted February 5, 2013 Author Report Posted February 5, 2013 Do GP's have a pass-through? Maybe you get in through the trunk and then through there? Maybe some of them do, not mine. I had an idea to knife out my back seat and crawl through. But there is a metal brace under the rear shelf and I wouldn't fit. Quote
GOT2B GM Posted February 5, 2013 Report Posted February 5, 2013 Could always cut the door handle just above the lever, pry it away from the door and then actuate the rods. Quote
Cygnus Posted February 5, 2013 Author Report Posted February 5, 2013 (edited) Dude, breaking into cars isn't hard. Doing it without damaging things so I can continue to drive it without paying for repairs is what I want. Genius idea!.....oh wait, it's not. If I could get into the car and open the door I could do that. Maybe I should just grab an cut off wheel and cut off the outer door skin. No, that seems dumb.... I rarely have any issues with my weatherstrip freezing to the metal of the body. So, any other bright ideas? Edited February 5, 2013 by Cygnus Quote
Cygnus Posted February 5, 2013 Author Report Posted February 5, 2013 I really like this idea! Do you ever have issue with getting enough pull to get the handle out? Quote
Cygnus Posted February 5, 2013 Author Report Posted February 5, 2013 Like in the plastic above the handle? I was thinking of cutting a small square below the handle and then pull a rod from in there. Then just patch the hole later. Quote
GOT2B GM Posted February 5, 2013 Report Posted February 5, 2013 I had to do it on my old 93 Z34, used a grinder with a cut off wheel, and carefully cut the pot metal handle right above the lever. Pryed it away from the door and using a screwdriver actuated the rods to open the door. Quote
Cygnus Posted February 5, 2013 Author Report Posted February 5, 2013 I am having a hard time visualizing this. I wish I had photos to go with. Quote
j_mezz Posted February 5, 2013 Report Posted February 5, 2013 How about using a hair drier on the door that sort-of works? There is a good door handle thread on here but you have to have access first... Quote
RPE1992GPSE Posted February 5, 2013 Report Posted February 5, 2013 (edited) I read through this thread and I may have missed the obvious. When you say your door handles don't work from the outside, are the actual handle levers broken so they just sort of flop around without any spring tension, or do they move normally and just not unlatch the door from the striker? Since you said it's a seasonal problem I am guessing the latter of the above scenarios is correct. I had a driver's door handle mechanism go out of adjustment just enough that it became a real pain in the ass to open the door until I corrected the adjustment. Edited February 5, 2013 by 1992GrandPrixSE Quote
Cygnus Posted February 5, 2013 Author Report Posted February 5, 2013 I took a plumber's torch to the latch area and it didn't work like it used to. I used to wave the flame around and then wait a minute or two, then the door would open. Quote
Cygnus Posted February 5, 2013 Author Report Posted February 5, 2013 If it gets really cold then it starts to get floppy. Currently it has the same resistance as it would when I was able to open the door. The second part is correct, they move with tension, but don't unlatch the door. Quote
WhatTheFehl Posted February 5, 2013 Report Posted February 5, 2013 I'll be honest, when my GP used to do this I used to just pull the handle swiftly but gently multiple times in rapid succession and usually by about the 3rd or 4th pull at most it would pop the latch. Quote
GOT2B GM Posted February 5, 2013 Report Posted February 5, 2013 Try pushing in on the door while pulling on the handle. If you need to cut the door handle, cut between the top of the lever and the lower mounting stud as shown. Quote
Cygnus Posted February 5, 2013 Author Report Posted February 5, 2013 Where your two fingers are? Quote
Cygnus Posted February 5, 2013 Author Report Posted February 5, 2013 Try pushing in on the door while pulling on the handle. You sir are a genius! I totally pushed in on the passenger door while pulling the handle. It worked and I got in! Thank you very much for the tips! Quote
Cygnus Posted February 5, 2013 Author Report Posted February 5, 2013 Now, where is that thread about adjusting the doors? lol Quote
