94 olds vert Posted January 20, 2013 Report Posted January 20, 2013 (edited) I'm 98% sure I'm leaking trans fluid near the radiator. There are two rubber lines that connect near the radiator. Is this for the trans cooler? A view from the top. Any one deal with this before? I just noticed this leaking yesterday. It hasn't been leaking for long. Edited January 20, 2013 by 94 olds vert Quote
94 olds vert Posted January 20, 2013 Author Report Posted January 20, 2013 I did some searching and came across a thread from Aaron. http://www.w-body.com/showthread.php/42405-Transmission-leak This sounds like the problem I am currently having? Quote
94 olds vert Posted January 20, 2013 Author Report Posted January 20, 2013 I removed the fans and got a better look. This is the spot that the fluid is dripping from. I checked the hose clamps and they are tight. Quote
