Rear speakers cutting in and out.
Does the 97 Cutlass Supreme have a separate amp from the head unit for the rear speakers?
You might possibly have a *Monsoon* system installed that made use of separate amps to drive the various speakers.
Is there a Monsoon logo on the face of the head unit? see the head unit pic in this link.
http://replacementradios.com/product_info.php?products_id=73
http://www.w-body.com/showthread.php/75607-The-quot-Monsoon-quot-Dilema
Edited by 55trucker
The factory head unit in my 96 was doing the same thing, threw an aftermarket one in, problem solved.
Rear speakers may have an amp running to them if you have the "upper level" system. The amp is a 3x5 grey box mounted behind the
knee bolster to the right of the steering column. Easiest way to check is look at your rear speakers thru the trunk. Look for 2 connectors
to each speaker.
Cutlass Supremes were never equipped with a Monsoon system from the factory.
OP: Do you have the amplifier mentioned? If you do, when you say your rear speakers are cutting out, is it the entire frequency bandpass or is it just the low frequencies?
Edited by 1992GrandPrixSE
I won't get a chance to check it until Sat or Sun. When I say cutting out, it is totally silent like it is getting no signal.
Okay. I'm not sure on how the amplifier is wired from that year. If anyone else knows or has a diagram, that would be helpful in tracking down the culprit. If the amplifier powers both coils in the rear speakers, it is likely at fault. If it merely powers the bass coils and the head unit powers the midrange and high frequencies (like in the older Cutlass Supremes), the fault lies elsewhere.
Someone here will be able to assist further, I am sure. :)
