problem2420 Posted January 4, 2013 Report Posted January 4, 2013 my 3.1 almost always doesn't or barely marks on my temp gauge unless sitting in traffic it reaches operating temp. I know Pontiac grilles are horrible I have a 86 firebird so i know Pontiac heating problems. but this one I'm stuck Quote
Night Fury Posted January 4, 2013 Report Posted January 4, 2013 Grille size should make hardly any difference, I'd start with replacing the thermostat Quote
Schurkey Posted January 4, 2013 Report Posted January 4, 2013 When my '92 Euro 3.4 wouldn't reach operating temp, the thermostat was stuck partially-open. That was the first time my engine oil didn't pass an oil analysis. Contaminated with moisture that wouldn't boil out due to low operating temp. Thermostat and oil change fixed everything. Quote
white96supreme Posted January 5, 2013 Report Posted January 5, 2013 I've been wondering about this with my cutlass. It warms up normally or what seems to be normal. I hooked up a scan tool and the ECT sensor reads about 150 degrees after running for 45 minutes. Maybe my t-stat is failed partially open also. Quote
problem2420 Posted January 5, 2013 Author Report Posted January 5, 2013 Well the car was sititing for 12 years and I was thinking about that, I have had the parts for a month so time for a coolant flush t stat and upper and lower hoses. Quote
72cuttysupreme Posted March 10, 2013 Report Posted March 10, 2013 It is without a doubt your thermostat. Mine did the same thing. I changed it and the problem was solved. Its not a hard fix. About 45 minutes of your time. Quote
