Highmilagecutlass Posted December 22, 2012 Report Posted December 22, 2012 I replaced my lower intake gasket's 50,000 miles ago and recently I noticed coolant dripping from below my belt tensioner and then dripping from below the motor mount. I'm tempted to pressurize the system and look for the leak but I fear that will make it worse. Thanks Quote
19Cutlass94 Posted December 23, 2012 Report Posted December 23, 2012 if the source of the leak is around the tensione area, your looking at a timing cover gasket. Unless the LIM is leaking again, and if you replaced it with the plastic version, its entirely possible. Quote
Highmilagecutlass Posted December 25, 2012 Author Report Posted December 25, 2012 So I looked today and it does appear to be leaking from the timing chain cover area, I was able to get a 1/4 turn on all of the bolts. Now I will keep an eye on the drip and pick up the gasket and a seal. Thanks for the input ! you guys are the best Quote
rich_e777 Posted December 27, 2012 Report Posted December 27, 2012 I noticed the same thing when i jack up the front end. My Haynes book says the oil pan has to come off to change the T cover gasket, but I was told on another thread( by that guy^ actually whos done it) that it isnt really necessary. I can feel my gasket and its like really soggy thin cardboard, and i wouldnt midn seeing how everything comes apart on that side of the engine. Been dealing with the distributor plug oring and im tired of looking at that side of a 3100:lol: Quote
19Cutlass94 Posted December 27, 2012 Report Posted December 27, 2012 Heres a few pictures of the timing cover off and oil pan still on. Quote
Highmilagecutlass Posted December 28, 2012 Author Report Posted December 28, 2012 Wow those are great pictures ! I'm planning to do a pressure test after I degrease the engine again and depending on what I see will tell me what gaskets to buy . I might have to take it all the way down to the head gaskets , whatever it takes ! Quote
Highmilagecutlass Posted December 28, 2012 Author Report Posted December 28, 2012 I noticed the same thing when i jack up the front end. My Haynes book says the oil pan has to come off to change the T cover gasket, but I was told on another thread( by that guy^ actually whos done it) that it isnt really necessary. I can feel my gasket and its like really soggy thin cardboard, and i wouldnt midn seeing how everything comes apart on that side of the engine. Been dealing with the distributor plug oring and im tired of looking at that side of a 3100:lol: There is a youtube video of a guy that changed the timimg cover gasket , it's a 4 or 5 video series .http://www.youtube.com/watch?v=de6apKi07yI Quote
