RPE1992GPSE Posted December 15, 2012 Report Posted December 15, 2012 I believe that the better sound you describe is from the increased RMS of the newer advanced ETRs, such as one from a 1993 Buick. I noticed a stark difference in volume between an older receiver with DNR and the newer ones. They look slightly different too. By the way, the old DNR receivers have nothing to do with Dolby. DNR is National Semiconductor's patented Dynamic Noise Reduction. DNR works differently from Dolby Noise Reduction in that it is not dependent upon an encoding/decoding system. Rather, DNR can work on radio broadcasts, CDs, and cassettes. Quote
Penglii Posted December 17, 2012 Report Posted December 17, 2012 By the way, the old DNR receivers have nothing to do with Dolby. DNR is National Semiconductor's patented Dynamic Noise Reduction. DNR works differently from Dolby Noise Reduction in that it is not dependent upon an encoding/decoding system. Rather, DNR can work on radio broadcasts, CDs, and cassettes. Interesting, learn something new everyday! Quote
Night Fury Posted January 6, 2013 Author Report Posted January 6, 2013 Replaced the amp with a Buick one thanks to Jay, PRESTO!!! PROBLEM SOLVED! Boy do I wish I did this earlier, 5 screws to get the glovebox out, then 2 10mm nuts for the amp. I HAS CLEAR RADIO NOW!!! Now to fix the cassette player so I don't have to hit FF or RR to listen to the radio lol Quote
redmetrix Posted January 26, 2013 Report Posted January 26, 2013 Glad to hear you installed a good amp! If I had known just how to get the amp out of a 88-89 GP, we could have fixed it that day you stopped by my house in Wisconsin. I have a couple of those amps at my house. I have a few 90-93 Buick/Pontiac radios and they use that same amp. Quote
Night Fury Posted January 26, 2013 Author Report Posted January 26, 2013 Thanks! Yeah this is one job that was much EASIER than expected. Quote
Revrip1 Posted September 27, 2014 Report Posted September 27, 2014 Hello, I have the same problem with my 1991 Oldsmobile Toronado Trofeo. It has the Visual Information Center (touch screen) that controls the radio. I know that the radio receiver is under the center console and this is where the speakers are all connected to. Also the antenna cable is plugged into it also. Then that unit is under the center console is plugged into the Visual Information Center. I have replaced the alternator, spark plugs and wires, tried a different antenna and still have ignition noise and very poor radio reception. I was just curious if anyone would happen to know where I might find a new radio receiver box? Or which different car models use the same one as mine? Thanks and please reply! I am at my wits end with this problem and any help would be greatly appreciated. Thanks again and hope to hear from someone soon!!! Revrip1 Quote
Psych0matt Posted September 27, 2014 Report Posted September 27, 2014 Hello,I have the same problem with my 1991 Oldsmobile Toronado Trofeo. It has the Visual Information Center (touch screen) that controls the radio. I know that the radio receiver is under the center console and this is where the speakers are all connected to. Also the antenna cable is plugged into it also. Then that unit is under the center console is plugged into the Visual Information Center. I have replaced the alternator, spark plugs and wires, tried a different antenna and still have ignition noise and very poor radio reception. I was just curious if anyone would happen to know where I might find a new radio receiver box? Or which different car models use the same one as mine? Thanks and please reply! I am at my wits end with this problem and any help would be greatly appreciated. Thanks again and hope to hear from someone soon!!! Revrip1 I don't mean to hijack this thread, but even thouygh it's not a w body, you need to post up some pics of that beauty Quote
Revrip1 Posted September 27, 2014 Report Posted September 27, 2014 Hello, Yeah my 1991 Oldsmobile Toronado Trofeo has the exact same problem. Whining and static in the radio. It also has poor radio reception. I have replaced the alternator, spark plugs and plug wires. I also tried a different antenna and it still has the same issues. So my question is where do I find a new radio receiver box? My car has the Visual Information Center(touch screen display) that controls the radio. The radio receiver is under the center console and is connected to the Visual Information Center(touch screen display). I just need to know if there are any other cars that might use the same radio receiver box or where I might be able to get another one for my car? Thanks and hope to hear from someone soon, Revrip1 Quote
Turbocharged400sbc Posted September 27, 2014 Report Posted September 27, 2014 run an aux ground wire from the radio/dash harness ground to the battery. what your describing sounds like part of a ground loop noise issue Quote
Revrip1 Posted September 27, 2014 Report Posted September 27, 2014 Thanks for the reply! I will try that and see what happens. Also, I will try and post some pictures later today. Thanks again! Quote
