Engine swap Q's.. No crank, no fuel pump
Ok well I got the engine. Put I have so issues. I have a plug I don't know where it goes. Everything is plugged in but I have plugs left still. I know 1 wasn't in when before I pulled it out.
Then I have this one plug on the coil pack. I believe it goes down on a sensor on the back side of the block.
So everything I can plug in is plugged in. But the car wont crank over and I can't hear the fuel pump prime. The ABS does its little thing though. All the power inside the car, lights, all that stuff works.
The car has set out side for about a year without a battery or an engine in it.
Edited by bkaab
the only sensor that plugs into the ICM is the 7X crank sensor. without that connected, the engine won't fire. doesn't solve your no-crank issue though.
Connectors in first and second pics. One looks like purge solenoid (behind coil pack), the other for speed sensitive steering (would plug into P/S pump if your car has that option). Last plug looks like crank sensor, back middle of the engine block just above the oil pan. This would be the opposite end of the harness that plugs into the ignition module.
I already have the purge solinoid plugged in. The plug looks just like the red one. Switched starters still nothing.
1996 has two connectors for the purge, the solenoid and a vacuum valve.
Ya wouldn't happen to have a diagram of the vacuum routing to these would ya?
Is there a way to delete the evap system? Or a better complete diagram. Im missing lines I think. Theres some weird vacuum things up with this car. Ive got the car to fire but then it revs up and dies.
I had it running at one point but it was idling high but pretty smooth.
Edited by bkaab
that's the entire emissions system vacuum diagram. the only other vacuum stuff is for the HVAC.
