Turbo Uprgrade
Is the GT2871R a direct bolt on or does it require some modification to fit?
It's sortof a direct bolt in... this TGPforums thread will give more info.
http://www.tgpforums.com/index.php?topic=4929.0
You need a bunch of off-the-shelf lines and fittings and a custom tune, but other than that it's pretty much bolt in to a TGP. If you are well prepared you can have it installed in a weekend and then spend the rest of your time working on the tune.
If you are trying to attach it to a NA engine, it's obviously not anywhere near as simple... I just have to throw that out there...
