tazman11683 Posted November 10, 2012 Report Posted November 10, 2012 this is getting kinda annoying lol just put a tranny in 3 weeks ago then had to pull it all back out to fix a leak in the tranny than back in than the oil pump went a week ago got a junk yard motor and just got it ready and sitting back in the car all i can say is through the top is the fastest and easiest way to pull motor and tranny as 1 after u pull the half shafts it takes about 45 min to unhook the harness easy if u unplug it over by the computer that unhooks the injector and all top end sensors the other harness is the cooling fans starter speedo and 2 of the icm plugs that harness stays in the car pull the fans and the radiator all that u have after that is 2 exhost bolts and 2 motor mount bolts on each side hook up the picker and wiggle it out we got it down takes me and a friend about 30 minutes to pull it other cool part of pulling motor and tranny as 1 is its self standing with them bolted together you can just sit it on the ground it stands perfect Quote
RobertISaar Posted November 10, 2012 Report Posted November 10, 2012 i've said it before, i'll say it again. W-body engine/trans removal, actually not that bad considering how much stuff is getting moved around. W-body battery replacement, FFFFFFFFUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU Quote
tazman11683 Posted November 10, 2012 Author Report Posted November 10, 2012 i've said it before, i'll say it again. W-body engine/trans removal, actually not that bad considering how much stuff is getting moved around. W-body battery replacement, FFFFFFFFUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU only thing i hate about replacing my battery is reprogramming everything and getting my idle relearn so much shit to set in the international Quote
tazman11683 Posted November 10, 2012 Author Report Posted November 10, 2012 i've said it before, i'll say it again. W-body engine/trans removal, actually not that bad considering how much stuff is getting moved around. W-body battery replacement, FFFFFFFFUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU i also dont get y people remove them by removing the cradle thats way more work than pulling them out the top Quote
19Cutlass94 Posted November 10, 2012 Report Posted November 10, 2012 I've pulled the motor/trans so many times in my car, I've got it down to a science. Quite sad actually... Sent from my iPhone in some random spot of Texas. Quote
tazman11683 Posted November 12, 2012 Author Report Posted November 12, 2012 I've pulled the motor/trans so many times in my car, I've got it down to a science. Quite sad actually... Sent from my iPhone in some random spot of Texas. do you pull them out the top like me or out the bottom like others ? Quote
DefEddie Posted November 12, 2012 Report Posted November 12, 2012 I pull just engine from top. If tranny needs pulled as well I just drop the cradle out the bottom and go. By myself takes about 3hrs either way. Quote
Schurkey Posted November 12, 2012 Report Posted November 12, 2012 What do you suggest for a popped transmission? Top or bottom? Quote
94 olds vert Posted November 12, 2012 Report Posted November 12, 2012 After dropping the cradle in a W body, I would much rather take the engine out the top. Quote
19Cutlass94 Posted November 12, 2012 Report Posted November 12, 2012 Ive always pulled the motor/trans out from the top. Quote
Timm Posted November 12, 2012 Report Posted November 12, 2012 I've been dropping it out the bottom recently, but that's been because of headers in a 3.8l 1st gen. Took about 4 hours from start to finish to drop it out the bottom, about 3 out the top.. Only thing going out the top is removing the hood by yourself. Not so much heavy as extremely bulky. Quote
DefEddie Posted November 12, 2012 Report Posted November 12, 2012 For pulling tranny really depends on tools available. I have a bar for holding the engine in the car while dropping the cradle/tranny only. I do it that way depending on if i'm using a lift or what the engine is. On 3800's it is too easy to simply drop the cradle with everything attached if you have no lift and need to pull tranny. I would think it takes longer to hang engine and pull cradle/tranny on ground. Quote
tazman11683 Posted December 7, 2012 Author Report Posted December 7, 2012 I've been dropping it out the bottom recently, but that's been because of headers in a 3.8l 1st gen. Took about 4 hours from start to finish to drop it out the bottom, about 3 out the top.. Only thing going out the top is removing the hood by yourself. Not so much heavy as extremely bulky. ya the hood is kinda tricky with one person Quote
