ron350 Posted October 26, 2012 Report Posted October 26, 2012 Has any one ever used Delphi replacement fuel injectors? I see that Advance Auto and Rock Auto sells them but I have never heard of them before. Quote
RobertISaar Posted October 26, 2012 Report Posted October 26, 2012 Delphi would be OEM, so i would expect decent results from them, to say the least. Quote
Galaxie500XL Posted October 26, 2012 Report Posted October 26, 2012 Delphi parts are genuine GM parts now. GM created Delphi in the mid '90's, then "transferred" Delco to Delphi. Many GM parts that prevously would have said "Delco" are now Delphi. Has any one ever used Delphi replacement fuel injectors? I see that Advance Auto and Rock Auto sells them but I have never heard of them before. Quote
ron350 Posted October 27, 2012 Author Report Posted October 27, 2012 Thanks for the replys and the information. Quote
Crazy K Posted October 27, 2012 Report Posted October 27, 2012 it may be unnecessary to buy new, but either way the job could be done. Use of a multimeter can confirm that the ohm spec is correct and balanced between your injectors, they should all be around 11.5 to 12.5 ohms. Quote
R Crusoe Posted February 2, 2013 Report Posted February 2, 2013 Use Bosch DRI injectors instead. Contact Linder Fuel Services in Speedway, Indiana to see if they have those for your engine. Quote
mfewtrail Posted February 3, 2013 Report Posted February 3, 2013 If you order through advance auto, be sure to get them online and use the largest discount code you can find. Quote
