I recently found a digital gauge cluster in the junkyard out of an 89 Cutlass and believed the wiring harness was the same as in my 92 convertible. However when I tried to put it in, I found out they are slightly different. I was wandering if anyone has done this swap and if so what tips do you have? Thanks a lot for any help.
Thanks for your reply. It didn't turn on or anything. I grabbed the plug out of the same car and compared it to mine and I think there are two or three additional wires on the digital cluster plug than on mine.
You are either doing to need to make an adapter or move around the pins on your current plug to match the ones for the Digi cluster.
Okay that's what I figured. I just looked at the link you sent me, that helped a lot. Thanks again.
