Differences between 3.1 and 3100 heads
I have seen a lot of you post that you are using heads from a 3100 because they are better. Hell.....even Jeff M I think is using them.
What are the differences?
Do you have to modify anythink if i wanted to use heads from a 3100?
If I use 3100 heads, would i still benifit from using proformance roller rocker arms, springs, and pushrods?
Are the heads from a 3100 the same as a 3400??
You have to use the whole 3100 top end: plenum, intake manifold, and exhaust manifolds if you want the heads. Ports don't line up with MPFI parts.
The heads flow 17% better on the intake and 30% better on the exhaust, when compared to aluminum MPFI heads. The intake valve is 1.76" vs 1.72". Not sure about differences in plenum and manifolds, though.
Personally, I feel like if you're changing the whole top half of the engine anyway, why not go ahead and change the bottom half too?
The 3100 has a roller camshaft and the block is stiffer and better reinforced.
That sounds like too much to change......
I will just get the ones i have Ported & polished.
And Shawn brings up a good point too.....but I already have torn apart the bottom half of the motor and it looked really good. I just have to order the main bearings & some other stuff,....It's comin along. I just was not sure what would need to be changed....
Good news is that if you keep the 3.1 bottom end, you can get a performance camshaft from GM for under $100...with the 3100 you have to get a stock one custom ground, which would be minimum $250+
Actually Brian, My brother-n-law and I got a quote from comp cams for $180.00 .......
