91 pontiac grand prix
I have a 91 grand prix and since it started getting cooler my car has a real bad gasoline smell when started and the heater is running, i dont have any service engine light but i do have a check gauges and the fuel light is always on. Does anyone have any idea what may be causing this?? Thanks for any and all help
I know what causes the low fuel light and check guage light to be on constantly. There are 15 pins in the back of the cluster that need to be resoldered.
As for the fuel smell when using the heated I haven't a clue.
Where exactly is the cluster?? i am kinda slow LOL and thank you very much
The guage cluster. It's the unit that houses all of the gauges and the check guage and low flight oh have on. If oh searh the forum there is a we're up on how to fix it. I have done it wasn't that hard.
I dont want to sound dumb (probably to late LOL) but how do i get to the guage cluster i took off lower cover and found bunch of wires going into connection box and also along the top of steering column there is a bunch of wires please help thanks
http://www.w-body.com/oldsite/service/checkgauges.html
That is a good link to repair the cluster once you get it out. In this car you will need to remove the dash pad to get the cluster out. It's not that big of a deal to do so. There is only a couple bolts that hold it down and the rest is clipped in.
If your car has a HUD(heads up display) you will need to remove that first before the dash pad comes off.
FWIW, i haven't used the screws for the dash in a long time with no issues, so once they're out, it's probably pretty safe to just not use the again.
