jake91 Posted October 7, 2012 Report Posted October 7, 2012 I'm getting this vibration from my car when i get above 60mph it doesn't get bad till 75mph though. now if i hit the throttle around 80mph it will shake hard enough to rattle things in the car, and once i let of it goes back to just a vibration. it doesn't do this at all under 60mph, and the acceleration shake doesn't start till 75+. I am thinking bad tires or a CV axle. thoughts car has only 60k miles Quote
Night Fury Posted October 7, 2012 Report Posted October 7, 2012 My guess is axle, my 04 did the same thing. Quote
Timm Posted October 11, 2012 Report Posted October 11, 2012 Cheapest thing to try is a quick balance, but it's fairly un-common (not 100% unheard of though) for wheel weights to fall off... Sometimes you can have someone else drive your car on the e-way while you drive near it, watch each one of the wheels... Sometimes if it's really bad, you can actually see the wheel bouncing. Quote
jake91 Posted October 13, 2012 Author Report Posted October 13, 2012 Well i feel so freaking stupid. this is embarassing. the vibration is all my fault due to me neglecting the gtp for a couple months. i took it to discount today to air up the tires and they were all 20lbs low and unevenly worn as a result. still need to get them rebalenced. but it is a ton better with just air so laugh all you want and make fun of me. i deserve it Quote
Euro Posted October 13, 2012 Report Posted October 13, 2012 Meh, it happens. Has the temperature changed down there in the last few months? Up here I'm sure there's a more drastic change, but my tire pressure changes with the seasons. I was going to say axle too though Quote
carkhz316 Posted October 13, 2012 Report Posted October 13, 2012 Could have a leaky tire too. You know, valve stem, bead, nail. Quote
jake91 Posted October 13, 2012 Author Report Posted October 13, 2012 one is leaky it was down to 13 all the rest were at 18-20. last time i aired them up it was 110* after just driving 40 miles so the tires were hot. it is now 75* degrees out Quote
RobertISaar Posted October 13, 2012 Report Posted October 13, 2012 well, good advice for anyone having strange issues with weather change. Quote
Silentkillzr Posted October 13, 2012 Report Posted October 13, 2012 Lol my cars always loose a significant amount of air in between seasons, I keep the compressor ready lol Quote
WhatTheFehl Posted October 13, 2012 Report Posted October 13, 2012 Yeah the past few weeks we've gotten a shit ton of calls and people coming in "My tire pressure light is on!!! I HAVE LEAK!!". The change in weather has had a huge effect. Quote
jake91 Posted March 21, 2013 Author Report Posted March 21, 2013 Just wanted to update this as a possibility for others. I finally found the vibration and its fixed. New tires helped and so did a cv axle, but what finally fixed it was new engine mounts Quote
Schurkey Posted March 21, 2013 Report Posted March 21, 2013 Just wanted to update this as a possibility for others. I finally found the vibration and its fixed. New tires helped and so did a cv axle, but what finally fixed it was new engine mounts Glad for the update. I have NEVER seen a vibration problem caused by tires that got worse when additional power was applied. Additional speed, yes. Additional power without (much) change in speed--no. When power is applied, and the vibration gets worse, it's always something else in the powertrain--axles, mounts, bearings, etc. Not tires. Quote
Venom Posted March 24, 2013 Report Posted March 24, 2013 I can usually tell when my Blazer needs air in the LF tire because it will start riding like crap and pulling . So I just pull it in the shop every week or so and top the pressures off and clean the windows/top off washer fluid. Quote
Schurkey Posted March 25, 2013 Report Posted March 25, 2013 I can usually tell when my Blazer needs air in the LF tire because it will start riding like crap and pulling . So I just pull it in the shop every week or so and top the pressures off and clean the windows/top off washer fluid. Because fixing the leak would be more trouble than dicking with it every week??? Quote
Venom Posted April 2, 2013 Report Posted April 2, 2013 I do like 10 tire repairs a day at work, I really dont have the energy to pull mine in and clean/reseal it. Quote
