Suggestions for altering the lug spacing?
The 1st Gen is a 115mm 5 lug pattern right?
Crap... I'm flirting with the idea of using the 16x7 alloy rims that came with the 96 Beretta.
The problem is that it's a 100mm spacing.
Would this be possible without an adaptor?
No, you'll either find a smaller adapter or replace the hub.
Not to discourge you, but I don't believe you'll be able to find any adapters that will fit.
- Erik
almost exactly the same rims came on newer lumina apv's, which unless they changed the bolt circle of the vans are 5x1115 just like w-bodies.
Yep. The exact same style in a 115mm pattern. The only problem with it is the 15x6 size.
Sometimes GM really just pisses me off.
