GP1138 Posted September 29, 2012 Report Posted September 29, 2012 I have obtained a nicer 1998 gauge cluster for my '97. It goes in just fine, the only issue is the stupid fuel gauge jumps and then just falls to empty. Any ideas on what I need to do to make this work? Quote
RobertISaar Posted September 29, 2012 Report Posted September 29, 2012 taking a look at the diagrams now: 97 used a simple setup, like the earlier cars, has a sender located in the tank, wire runs from the cluster to the sender, creates a variable resistance, which moves the needle around. 98 is different.... still a level sensor, but it's read by the PCM and the PCM drives the fuel level signal itself, probably via PWM instead of a variable resistance. the 97 uses a 0-90 ohm sender, the 98 uses a 40-250 ohm sender, so simply bypassing the PCM control isn't going to be simple. long story short: 97 cars need a 97 cluster unless you swap the PCM to a 98+ and redo the wiring to act like a 98 car. Quote
GP1138 Posted September 30, 2012 Author Report Posted September 30, 2012 FFFFFUUUUUU Thanks a bunch. I guess I'm going to screw with swapping the surrounds and faces. Quote
runt Posted September 30, 2012 Report Posted September 30, 2012 That isn't too bad to do. I added a cluster overlay on my 01 and those units come apart pretty easily. Quote
