Won't shift from first
00 GTP Trans won't shift from first. First and reverse work fine, no slippage. Trans/fluid looks good and does not smell burnt. Fluid level is correct.
Figure it's going to need a trans as I've check connections, ohm'd the solenoids and have no codes whatsoever.
Just thought I'd toss this out there for maybe some ideas or suggestions on something I may have missed.
Thanks for any input.
join the club,I have the same problem with my 4t60-e,it just happened after the vacuum hose came off and I put it back on,if I figure it out,I'll let you know what it was..
