scorpion_x9 Posted October 31, 2003 Report Posted October 31, 2003 I want to change my fuel filter. It'd be really easy if it wasn't rusted (AND MADE THE NUT STAINLESS STEEL TOO, WOULD HAVE HELPED!! :x ) and I would've had it done in about 10 minutes. I used mass amounts of rust eater (the PB Blaster stuff with the yellow cap.) and no luck, I even used a special wrench to try to un do it. All I accomplised was causing a nearly rouned nut. So... I figure I might cut it and substitute a different filter and use a short peice of rubber fuel line. I'd really like to keep the existing line intact, anyone have any ideas on how to avoid cutting the line? Quote
Slade901 Posted October 31, 2003 Report Posted October 31, 2003 Use a pipe wrench (monkey wrench). Two of them. Quote
