Got me NEW AutoXray today!!!
I do love it! But so far the only things I've been able to scan are:
1) PROM ID
2) Coolant Temp
3) Start Up Coolant Temp
4) Throttle Sensor
5) Throttle Angle
6) Engine RPM
7) Vehicle Speed
8) Oxygen Sensor Voltage
9) 02 Cross Counts
10) Block Learn
11) BLK LRN Cell
12) Integrator
13) Idle Air Mtr Pos
14) Desired Idle
15) Barmotric Pressure
16) MAP Sensor
17) Manifold Air Temp
18) Fuel Pump Sensor
19) Battery Voltage
20) Spark Adcance
21) Desired A/F Mix
22) Injector Pulse
23) CCP Duty Cycle
24) Knock Retard
25) Engine Run Time
26) Catalytic Temp
27) Knock Sensor
28) TCC Status
29) A/C Clutch
30) Hwy Spark Advance
31) EGR
32) Air Switch Solenoid
33) Park/Neutral
34) Third Gear
35) Fourth Gear
36) A/C
37) Oxygen Sensor
38) IAC Motor Reset
39) Fuel Cut Off
40) Learn Control
41) Rich Lean Flag
42) Loop Status
I'm concerned/confused about this, why can I only test 42 different variables, when the AutoXray manual shows over 100+ for GM OBD-I??
Is there any books or websites that you recommend for more information on what various readings SHOULD be? In other words, lets say my "Injector Pulse" is "10.3 mS", what the heck does that mean to me?? What good is the information, if I have no idea what I'm supposed to do with it? Any recommendations are truly apprecaited!:)
THANKS!
Well..
On those parameters you listed.. mostly ECM if not all ECM.. There are a bunch of other codes not related to ECM including ABS on certain GM cars. The ABS controller alone can add dozens of additional codes.
As for the injector pulse, we're talking about a Fuel Management paramater that is continously adjusted by the ECM (hence changing) when the car is running. It does this with the help of inputs from sensors and also preset fuel logic and algorithms so it is not easy to pinpoint specific reference numbers. If you turn your air conditioner on you should see a change in the pulse as the ECM is reacting to increased power demand.
If you really want to get into the whole complex world of ECM operation and programming you can read about GM EFI at this site:
http://www.customefis.com/GMEFI.html
You'll find excellent introductory info there..
Hmm.. you sure it was 10.3ms and not 1.3ms?
Just curious.. :)
