Nicutlass_Supremacy Posted August 31, 2012 Report Posted August 31, 2012 Recently when I start my car and put the gearshift in R position or D it seems that I´m in N position because the car doesn´t move. If this happens (because it doesn´t happen every time) I try another time changing gears and the car moves. I checked the automatic fluid because there´s a leakage within the gasket but it´s above the level, could this be the problem?. There´s a way to check the level? What I do is turn on the car and put all the gears then I turn of the car and check the level. Thanks!!! Quote
RobertISaar Posted August 31, 2012 Report Posted August 31, 2012 trans fluid needs to be checked with the engine running, preferably with the fluid warm/hot. Quote
