kayzee2405 Posted August 27, 2012 Report Posted August 27, 2012 (edited) i was wondering if the basic digital is compatible with the ub3 im having problems with the stock gauges and found a set with almost the same miles but they are ub3 are the plugs the same and would i have to wire anything up anyone please help thanks the car is a 92 cutlass s 4 door 3100 Edited August 27, 2012 by kayzee2405 Quote
94 olds vert Posted August 27, 2012 Report Posted August 27, 2012 I am sure it can be done. I don't know the specifics on the base model digi cluster. The harness will be close, but if you plug it in it probably won't work. The biggest issue would be getting a tach signal from the AlDl and that's not even that hard to do. I'm not sure how close the pinouts are between the base and ub3 clusters. Quote
94 olds vert Posted August 27, 2012 Report Posted August 27, 2012 I noticed you made a post in the group buy digi adapter thread. That thread has been inactive for quite some time. http://www.w-body.com/showthread.php/53113-Digi-UB3-adapter I have a thread all about this. Lots of good info in that thread. Quote
kayzee2405 Posted August 29, 2012 Author Report Posted August 29, 2012 Thank you it does help but would anyone be able to make one for me I can wire and enjoy it but never messed with changing the pins on the plugs and that link you sent that guy says I'd need to change a couple sensors but I can't find different ones would anyone have part numbers for the ones I'd need to get and I couldn't find the data connector for the tach wire lol I want to make this as easy as possible if no one will make a plug is there a way to get the end I need sorry for all the questions I want to have everything in order before ordering the gauges Quote
kayzee2405 Posted August 31, 2012 Author Report Posted August 31, 2012 Ok here's an update on my discussion I bought the gauges from a 91 supreme they are sending the plug for it and I'd like to make an adapter from the old gauges do I can simply plug and play anyone know if the wire colors are different I'm looking for a diagram for both cars any opinions I looked at that link but it doesn't say what year it's for Quote
