xennith Posted August 20, 2012 Report Posted August 20, 2012 So I've heard this rattle before in other W's but I'm not sure what it is. My vert did it before and after the new shocks. It's a 95 with 101k miles. The noise happens when I hit a bump so I'm guessing its got something to do with the suspension, and I don't think it's related to braking. The old shocks were leaking so I'm thinking they may have been original, the new ones are form Autozone. I also replaced tie rod ends and then had the alignment done by Tire Discounters when I got new tires. They didn't mention any issues but they weren't necessarily looking for problems either. My friend's '05 G6 is making a similar but not as loud noise. Any ideas? I don't even know where to start with this one Quote
GOT2B GM Posted August 20, 2012 Report Posted August 20, 2012 try adding a washer under the front strut shaft nut. Quote
Red Nightmare Posted August 21, 2012 Report Posted August 21, 2012 Does it also make rattling or thumping noises sometimes when turning, even if the steering seems smooth? My 94 GP does this crap, I have yet to pull out the strut on the passenger side (where noise is coming from) but I am gonna do that and see if something is jacked. I think the best thing you can do until you find the noise is make sure all the other suspension components are good at least. Especially the ball joints and control arms and their pivot bolts and mountings. Quote
Gunboat Posted August 21, 2012 Report Posted August 21, 2012 I had had a problem with the rubber bushings in the front calipers going bad and making a rattling noise,does it stop if you ride the brakes? If so,check that out. Quote
xennith Posted August 21, 2012 Author Report Posted August 21, 2012 I haven't noticed it being better or worse during turns or breaking. I was guessing it might be a bushing somewhere. Quote
pshojo Posted February 19, 2013 Report Posted February 19, 2013 Front Brake rattle? For the longest time i thought the rattle over bumps was coming from the front was ball joints. I replaced front ball joints, struts, and calipers. I still have rattle going over bumps. I had had a problem with the rubber bushings in the front calipers going bad and making a rattling noise I compared both my 95 cutlass's. When i grab a hold of the front calipers that i replaced, I can get them to move slightly. The other car i haven't done anything to, won't budge at all. What can cause this? is there something that i should've replaced? Quote
rich_e777 Posted February 19, 2013 Report Posted February 19, 2013 Rack and pinion mount bushings going out? Had my outer sway bar mounts come loose once that made a thumping sound, Im thinking it has something to do with the strut bumper or bellow, has to be, everything else seems tight and secure. Have same/similar issue. Kindof almost sounds like something vibrating against the inner wheel well area right? Quote
pshojo Posted February 19, 2013 Report Posted February 19, 2013 Yeah, sounds like that. with only 46k miles. the bolt broke that held the out sway bar bushing. So i replaced the control arm. I thought the noise was coming from there. but still there. If you turn your wheel enough so you can grab your brake caliper, how much movement do you have? Quote
rich_e777 Posted February 20, 2013 Report Posted February 20, 2013 I know the rotor can be moved a bit, but both caliper are pretty secure IIRC, i`ll jack it up tomorrow and get in there and see. Quote
